Posts
By Copernic · Posted
Microsoft PC Manager 3.17.4.0 (Offline Installer) by Razvan Serea With Microsoft PC Manager, users can easily perform basic computer maintenance and enhance the speed of their devices with just one click. This app offers a range of features, including disk cleanup, startup app management, virus scanning, Windows Update checks, process monitoring, and storage management. Microsoft PC Manager key features: Storage Manager- easily uninstall infrequently used apps, manage large files, perform a cleanup, and set up Storage Sense to automatically clear temporary files. Health Checkup feature -scans for potential problems, viruses, and startup programs to turn off. It helps you identify unnecessary items to remove, optimizing your system's performance. Pop-up Management - block pop-up windows from appearing in apps. Windows Update - scans your system for any pending updates. Startup Apps - enable or disable startup apps on your PC, allowing you to optimize your system's startup performance. Browser Protection - rest assured that harmful programs cannot alter your default browser. Also enables you to change your default browser. Process Management - allows you to conveniently terminate any active process, ensuring optimal system performance and resource utilization. Anti-virus protection - Fully integrated with Windows Security. Safeguard your PC anytime. Quick Steps: Download Microsoft PC Manager Offline Installer (APPX/MSIX) with Adguard Adguard serves as a third-party online service, offering a user-friendly method for directly downloading appx, appxbundle, and msixbundle files from the Microsoft Store. Official download links will be generated for both the app's various versions and its dependency packages. How to download Microsoft PC Manager Offline Installer (APPX/MSIX) 1. Initially, you must find the app URL within the Microsoft Store. Access the Microsoft Store via your browser and search for "Microsoft PC Manager". Once located, copy the app URL, which includes the product ID, either from the address bar or from the provided link below. https://apps.microsoft.com/detail/9PM860492SZD 2. Now paste the app URL into the designated area, then click the check mark button to produce a direct download link. 3. To download, right-click the relevant link and select “Save link as…” from your browser's menu. Occasionally, Microsoft Edge may flag the download as insecure. In such cases, consider utilizing alternative browsers such as Google Chrome or Firefox to successfully complete the download. Microsoft PC Manager is a completely free tool optimized exclusively for use on Windows 10 (version 1809 or newer) and Windows 11. Download: Microsoft PC Manager 3.17.4.0 | from Microsoft Store View: Microsoft PC Manager Home Page Get alerted to all of our Software updates on Twitter at @NeowinSoftware -
By +BudMan · Posted
You might want to update to 1TB drive. They are not very expensive these days, there are plenty of options - simple look I would think you could find a 1TB ssd or even nvme somewhere between 50 and 100 bucks. when I have moved to larger ssds in laptop in the past, you can just connect the drive via usb - image. Then take the old drive out, put in the new drive and there you go.. If your concerned about how much space you have left this prob your best bet.. -
By FMH · Posted
I see! Wasn’t aware of that. Even though they started off with desktop app for Mac before Windows. Should be on it’s way soon! 🤞 -
By skinnyJM · Posted
support.microsoft.com/en-us/topic/microsoft-defender-update-for-windows-operating-system-installation-images-1c89630b-61ff-00a1-04e2-2d1f3865450d -
By SkyDX · Posted
It's a Developer Beta 1 not even a Public or User Beta, I doubt any of the design is 100% finalized yet.
Recent Achievements
viraltui earned a badge
serfegyed earned a badge
firey earned a badge
fettermanj earned a badge
Popular Contributors
Tell a friend
