difference between +R and -R?
  I8PP said:
Data on +R is supposedly more reliable in terms of the way it is burned onto the disc. It has slightly less disc space than -R (7MB approx).
http://en.wikipedia.org/wiki/DVD-R
http://en.wikipedia.org/wiki/DVD+R
oh ok, thanks.
  stevan said:
working at bestbuy for two years, that was by far the most common question of all.
i'll tell you the same i told every customer that asked me that question:
there's no difference significant enough, so buy whichever is cheaper....
means can't get u ............
