FEAR Combat problem - CD key
I've downloaded FEAR Combat again, but bizarrely, I can't enter my CD key in the boxes!
It's too big to go in the boxes. If it's 4 numbers or short letters, it fits no problem, but otherwise, 3 big letters is the limit.
This is 1.07, BTW. There isn't a full 1.08 version, and I can't find a 1.00 version to download, so I'm stumped, unless someone here can help?
https://www.neowin.net/forum/topic/617828-fear-combat-problem-cd-key/
  lonelycooler said:
isnt this a free game?, just request a new cd key
It's not that the CD key isn't working. It's that the boxes are too small to enter it in. And yes, I did get another CD key, but that one didn't fit, either!
Does anyone know where I can download the 1.00 version, because that one worked perfectly!
  Aq3e said:
Its a graphical issue, try to click the box and enter the keys anyways may not look like its going to work but try it anyways, happend to me once . (on a really old laptop with even older videocard)
Doesn't work. It makes the notice noise when I try to enter the 4th letter/number, except on the last box, as it's all numbers.
I've tried some other methods. I've lowered the resolution, changed my visiual style, even changed the font size.
I had the same problem 4 months ago, but when I downloaded a fresh copy recently, it worked fine. I know it would be agonizing for you to download the 2 gig file again, but do it and try it.
  • 8 months later...
