- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
ProclaimDragon
Hi,
I've been using O&O Defrag 10 Professional for a while on Vista and I have the "OneButtonDefrag" activated.. However, I'm not sure it's working, I'm not sure the defragging is automated... How do I check that? I mean, I didn't manually defrag for a while and when analyzed the volume, it was quite high and I wasn't expecting that because I thought that automatic defragmentation was enabled and working. I opened Vista Task Scheduler and tried to look for something about O&O "OneButtonDefrag" but didn't find anything...
How do I make sure that it's enabled/working and/or how do I enable it if it's not enabled? (although the button is activated)
https://www.neowin.net/forum/topic/619729-oo-defrag-10-pro-automated-defrag-not-working/Share on other sites
12 answers to this question
