Chan Smith Posted March 23, 2008 Share Posted March 23, 2008 Is there a way to order power switch (button) and front usb 2.0 for a computer case? I think mine are going back but I love the case. Link to comment https://www.neowin.net/forum/topic/627293-computer-case-power-button-and-front-usb/ Share on other sites More sharing options...
Sikh Posted March 23, 2008 Share Posted March 23, 2008 Call the company that made your case and ask them. First check the warranty on your case. You might still be in warranty. My case has a 3 year warranty So if my front ports ever go, or Power / Reset button, then ill be ordering a new one at no charge :D. SO check your Warranty, if its only 1 year and yourve passed it, go ahead and call up the company and ask them if they have a solution for you. They should. Cheers. P.S. Can you still find the case online at sites like tiger, newegg, ebuyer, etc? Link to comment https://www.neowin.net/forum/topic/627293-computer-case-power-button-and-front-usb/#findComment-589287711 Share on other sites More sharing options...
StevoJD Posted March 23, 2008 Share Posted March 23, 2008 Warranties usually cover things like these. Call up or e-mail the company to arrange a replacement. However, if your case is a for example a Powmax, then you really have no warranty. Link to comment https://www.neowin.net/forum/topic/627293-computer-case-power-button-and-front-usb/#findComment-589287759 Share on other sites More sharing options...
Chan Smith Posted March 24, 2008 Author Share Posted March 24, 2008 The computer case is from abs I am sure they prob didn't make it because I have seen several cases that look just like it. StevoJD said: Warranties usually cover things like these. Call up or e-mail the company to arrange a replacement. However, if your case is a for example a Powmax, then you really have no warranty. Link to comment https://www.neowin.net/forum/topic/627293-computer-case-power-button-and-front-usb/#findComment-589288165 Share on other sites More sharing options...
Mindovermaster Global Moderator Posted March 24, 2008 Global Moderator Share Posted March 24, 2008 is it one of these 3? http://www.newegg.com/Product/ProductList....amp;srchInDesc= Link to comment https://www.neowin.net/forum/topic/627293-computer-case-power-button-and-front-usb/#findComment-589289059 Share on other sites More sharing options...
chconline Veteran Posted March 24, 2008 Veteran Share Posted March 24, 2008 Personally I would call warranty for this, if it still has warranty. :) Link to comment https://www.neowin.net/forum/topic/627293-computer-case-power-button-and-front-usb/#findComment-589289070 Share on other sites More sharing options...
Chan Smith Posted March 25, 2008 Author Share Posted March 25, 2008 Well I contacted abs. Don't know if it will due any good. I don't see the cases on there. The newegg one. http://www.newegg.com/Product/Product.aspx...N82E16811215003 I like that case alot. Does the cases on there come with the fans installed? chconline said: Personally I would call warranty for this, if it still has warranty. :) Link to comment https://www.neowin.net/forum/topic/627293-computer-case-power-button-and-front-usb/#findComment-589290412 Share on other sites More sharing options...
