VB.net Help - Importing .xls data into a listbox
Ok i am new to using VB.net, so as you can guess my skills are very limited.
So heres the problem. What i am wanting to do is import data from a .xls (excel file) and display that data in rows within a listbox. I have the open file box already working, i just cant seem to figure out how to get the data within the .xls file to display within the listbox. If it helps here is my code so far:
' Created by SharpDevelop.
' User: Chris
' Date: 4/16/2008
' Time: 8:32 PM
' To change this template use Tools | Options | Coding | Edit Standard Headers.
Public Partial Class MainForm
	Public Sub New()
		' The Me.InitializeComponent call is required for Windows Forms designer support.
		Me.InitializeComponent()
		' TODO : Add constructor code after InitializeComponents
	End Sub
	Sub Button1Click(ByVal sender As Object, ByVal e As EventArgs)
		openmunro()
	End Sub
	Private Sub openmunro()
		'creates a variable that can be used to read from a file
		Dim openMunroD As IO.StreamReader
		'dimensions a variable that lets the user open a file dialog box to open a file of the users choice
		Dim openfiledialog As New OpenFileDialog
		'gives the dialog box a title
		openfiledialog.Title = "Open Munro Data"
		Try
			'sets the initial directory to look at
			openfiledialog.InitialDirectory = Application.StartupPath
			'limits the file types that are displayed
			openfiledialog.Filter = "Excel Files (*.xls)|*.xls"
			'shows the dialog
			openfiledialog.ShowDialog()
			Catch
			MsgBox("The file was either not found or you did not open the file")
		End Try
	End Sub
End Class
Any help will be greatly appreciated :)
Many Thanks
1 answer to this question
You can read Excel files through the standard OLEDB layer. What you need to do, is setup a connection using ADO.NET, and pass in a specific connection string:
Provider=Microsoft.Jet.OleDb.4.0;Data Source=<path/to/file.xls>;Extended Properties=Excel 8.0;
There are a few things you need to do to your spreadsheet though, you need to create a named range which would become something akin to a virtual sql table. The top row on your spreadsheet needs to contain the column names, and you will then select all the cells that will make up your virtual table, and select Insert > Name > Define. The name you give this range will become the name of your virtual table.
Back in ADO.NET, you can then use standard SQL statements to manipulate the data.
SELECT * FROM People WHERE Age <= 50
Hope that helps!
    • #1 DP and #8 HDMI, you can connect both monitors to your motherboard. It's not just one or the other, you can use both at the same time.
    • So, I will see exactly ZERO ads, because I f**ked off the stupid Facebook/Meta ages ago. I don't miss any of it at all.
    • Thunderbird 139.0.1 by Razvan Serea Thunderbird is a free, open-source, cross-platform application for managing email and news feeds. It is a local (rather than a web-based) email application that is powerful yet easy-to-use. Thunderbird is clean and elegant by default, but easily customizable to match your workflow and visual preferences. It is loaded with unique and powerful features. Thunderbird is developed, tested, translated and supported by the folks at Mozilla Corporation and by a group of dedicated volunteers. Thunderbird gives you control and ownership over your email. There are lots of add-ons available for Thunderbird that enable you to extend and customize your email experience. Thunderbird gives you IMAP/POP support, a built-in RSS reader, support for HTML mail, powerful quick search, saved search folders, advanced message filtering, message grouping, labels, return receipts, smart address book LDAP address completion, import tools, and the ability to manage multiple e-mail and newsgroup accounts. Thunderbird 139.0.1 fixes: Thunderbird could crash when copying a local folder to IMAP Upgrade to 139.0 incorrectly switched Table View to Cards View Download: Thunderbird 139.0.1 for Windows (EN/US) | 32-bit | ~70.0 MB (Open Source) Download: Thunderbird 139.0.1 for Linux (EN/US) | 74.7 MB Download: Thunderbird 139.0.1 for Mac OS (EN/US) | 127.0 MB Download: Thunderbird 139.0.1 in other languages View: Thunderbird Website | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • It's both. Bazzite forked the game mode so it's not just simply running big picture mode like on full desktop.
      ClarkB earned a badge
      Epaminombas earned a badge
      Prestige Podiatry Care earned a badge
      rollconults earned a badge
      lilred1938 earned a badge
      130
      snowy owl
      97
