- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
JMann Veteran
Hi everyone,
A colleague of mine has been working on an Internal company website soon to be used as an Intranet, view the problem we are having below:
If you look at the Header you can see on the left & right sides that it has two stripes of white down the sides, now that Header image should be 800x200px which it is but yet everytime you upload it it shrinks it down but yet the Flash is still the correct size.
We have completely recreated the Header twice in Flash and both times we get the same problem, the sizes are correct in the HTML template, CSS and Flash file yet it still cuts it down in size.
Any idea's why this could be?
If it helps you can download the Template directory, the flash file is in Images directory called "Banner.swf"; I have uploaded the directory here:
Template Download File
Any help is massively appreciated, thanks. :)
https://www.neowin.net/forum/topic/631870-joomla-flash-problem/Share on other sites
1 answer to this question
