How do you change the width of the start button in StyleBuilder? I tried changing the width of the bitmap start bar image, but my new one appeared in the middle of the place where the start button is and had transparency around it.
Display Driver Uninstaller (DDU) 18.1.2.3 by Razvan Serea
Display Driver Uninstaller (DDU) is a utility for completely removing AMD/NVIDIA/INTEL graphics drivers and related packages from your system, attempting to eliminate all leftovers (including registry entries, folders and files, driver store).
Though AMD/NVIDIA/INTEL drivers can usually be removed via the Windows Control Panel, this uninstaller tool was created for situations where standard uninstall fails, or when you need to fully remove NVIDIA or ATI graphics card drivers.
After using this driver cleaner, your system will behave as though it’s the first time you’re installing a new driver—similar to a fresh Windows installation. As with all such tools, we recommend creating a restore point beforehand, allowing you to undo changes if issues arise.
If you're having trouble installing an older or newer driver, try it—there are reports that it resolves such problems. Recommended usage: The tool can be used in Normal mode but for absolute stability when using DDU, Safemode is always the best.
Make a backup or a system restore (but it should normally be pretty safe).
It is best to exclude the DDU folder completely from any security software to avoid issues.
You do NOT need to uninstall the driver prior using DDU.
Requirements: .NET Framework 4.8
Compatible with Windows 7, 8, 8.1, 10, and 11 (32-bit or 64-bit)
Note: Using on Insider Preview builds is at your own risk.
Display Driver Uninstaller (DDU) 18.1.2.3 changelog: All GPUs: Fixed hardware rescan issue when cleaning all GPUs without restarting or shutting down
UI: Added Guru3D mention in the About section.
General: Various fixes and enhancements.
Download: Display Driver Uninstaller (DDU) 18.1.2.3 | 1.7 MB (Freeware)
Download: DDU Portable | 1.2 MB
Links: Display Driver Uninstaller Home Page | Screenshot | Forum Get alerted to all of our Software updates on Twitter at @NeowinSoftware
That would be nice, if excel could refresh pivot tables without bugs. Frequently you refresh a pivot and all parameters get lost. Now this will happen automatically. Bravo MS!
The most corrupt and vile CEO any company ever had ! The only company that makes an insane amount of money decade after decade but doesn't deliver on even barely passable quality to customers, screws over partners and treats employees like trash
Anubis208
https://www.neowin.net/forum/topic/639411-help-with-tgtsoft-stylebuilder-how-to-change-start-button-width/Share on other sites
1 answer to this question
