Need help with Wine to execute child processes from parent process.
I need some help with mkv2vob running under Wine 1.0 in Ubuntu. The application is running but I get the message "Error getting mkv info!" when I attempt to transode the file. Googling the error message suggested that Windows users that got the error had security settings or applications preventing the parent process from executing child processes (/mkv2vob/tools/...exe's) that were required for the parent process. Is there a way to start a Wine application so that it can call these child processes? (assuming this is the problem).
Wine should be able to transfer calls to other apps, as long as they exist and are well-behaved in wine.
Alternatively, a little google showed me this is a PS3 video thing, is that correct? If so, I think ffmpeg might be able to do the job natively.
Well, I have come across some fairly complicated scripts using various *nix tools to demux the video, audio, and subtitle streams; hexedit the video format byte; and resample and remux the video and audio to a PS3 compatible file. There were reported quirks with all these alternative methods though, I just thought it would be easier to get mkv2vob working under Wine than to deal with all that nonsense.
    • Darwin Mach Kernel/ BSD. Which is both open source.
    • You mean BSD. The UNIX kernel is not open source.
    • I have been on Linux Mint full-time since Jan 2019. while there is a learning curve, it's worth it if you can make the switch, which I can. I mainly browse web, play some games (generally Lutris(Windows games), or through emulators (MAME/Mesen/Flycast etc) etc), and use a small amount of Windows programs (Foobar2000/7-zip/WinRAR/ImgBurn etc) etc. it's nice to dodge the bloat/BS of Windows as you can really feel Linux is all around faster, especially certain things. p.s. recently I enabled NTSync for games since Linux Mint recently offered the 6.14 kernel, which has NTSync support (it's not enabled by default though but you can enable it temporarily for your current boot of the OS through 'sudo modprobe ntsync')
    • A rotten article full of handwaving of anti-consumer practices. Aside from the fact that no, not even close to every piece of major software collects information about its users, ethical developers make such telemetry opt-in and allow it to be completely disabled. To use KDE Plasma as an example, you're shown a greeter upon first boot that gives users the option to send the developers telemetry, with the default being off and 'off' actually meaning off. Windows 10 has never offered that capability - only a promise that Microsoft will slurp up less of your data if you spend time tweaking 50 different privacy settings. There is still absolutely no way to completely opt out of sending Microsoft telemetry in any version of Windows 10 (or 11, naturally). Even using group policy in Enterprise editions only allows you to reduce telemetry to the bare minimum. Home-focused editions don't even get that option. Articles like this dismissing user privacy concerns as "FUD" are a part of the reason Microsoft felt confident enough to go so much further with Windows 11. I guess you get what you deserve in that respect. Personally, I finally made the move to Linux after 15 years or so of dabbling with it, but never really considering a permanent switch. Enjoy your bright, shiny Windows future. You asked for it, after all.
      smileyhead earned a badge
      K V earned a badge
      K V earned a badge
      CarlosABC earned a badge
      solidox earned a badge
      172
      122
