Help with Print Sharing on a Netgear MR814 Router
I just purchased this unit and had the internet up in a snap! Genuinely impressed.
However, I have a problem sharing a printer so far that I was hoping for some help with.
Printer is an HP PhotoSmart 1115 connected via USB via a USB HUB to COMPUTER A
COMPUTER A is a P3-600 Desktop running XP PRO, connected to the MR814 via RJ45 to Port 1. It has full internet access. Computer A is on a workgroup called HOME. IP is 192.168.0.10. I have shared out the printer on this computer as HPPS1115 (8 character) and rebooted.
COMPUTER B is a HP Pavillon ZE4200 Celeron 1.6 Laptop. running XP HOME It is using a wireless card and its IP is 192.168.0.11. It has full internet access, its workgroup is also HOME.
I have not been able to see the printer on the notebook at all. Does the client PC (COMPUTER B) need to have a login PROFILE that matches one on COMPUTER A?
Any help would be appreciated. Please let me know if I left out any pertinent information.
  Wolvereen said:
I just purchased this unit and had the internet up in a snap!?  Genuinely impressed.
COMPUTER A is a P3-600 Desktop running XP PRO, connected to the MR814 via RJ45 to Port 1.? It has full internet access.? Computer A is on a workgroup called HOME.? IP is 192.168.0.10.? I have shared out the printer on this computer as HPPS1115 (8 character) and rebooted.
COMPUTER B is a HP Pavillon ZE4200 Celeron 1.6 Laptop. running XP HOME? It is using a wireless card and its IP is 192.168.0.11.? It has full internet access, its workgroup is also HOME.
I have not been able to see the printer on the notebook at all.? Does the client PC (COMPUTER B) need to have a login PROFILE that matches one on COMPUTER A?
Any help would be appreciated.? Please let me know if I left out any pertinent information.
Make sure you have NetBIOS enabled.
I have two computer via my Linksys router, and have my Printer Shared in Windows XP.
I turned off Netbios Sharing connectivity for 6 months, I couldn't ever figure out what it was that broke my Networking until th:D week. :D
Make sure you go to the computer with the printer that its attached to and right click it an CLICK "Sharing" and give it a share name etc.
Then use the add printer wizard in your os to add it as a network printer from the remote pc that the printer is NOT attached to.
If netbios is enabled over tcp/ip on both computers and the printer is on and attached you should be able to use it across the network.
Make sure the computers both have the same Workgroup name / domain connection.
Windows XP Is smart enough that it will add it automatically as i've noticed in my printer folder of printers called "AUTO < printername> on <computername"
Thanks xStainDx -
I already have the printer shared as an 8 character file name (just to be safe). Both are on the same workgroup called HOME. I will try enabling NETBIOS now on both to try it again. Correct me if I am wrong though, I thought NETBIOS was only used in communicating to Novell based OS's? Is that not the case? I don't have NETBIOS installed on either of my WINXP PC's...
Thanks!
