prevent users using remote desktop
  barteh said:
I've just tried this on an account in AD called 'Test' which isnt a member of the local admins or anything.
I ticked the deny box but RD still loads fine.
I've tried re-logging on a few times as that user, but to no avail.
Does anything else have to refresh?
Your saying it "loads fine". Do you mean to block the act of using mstsc.exe and connecting and logging on to remote computer? Or to block the mere mstsc.exe from even opening?
Again -- what exactly are the users doing that you want to stop? That setting in AD has nothing to do with them running the remote desktop client and connecting to some box running remote desktop, etc.
I am going to take a guess you have users using remote desktop to access machines outside your network to say surf the net, play solitare, etc..
Is this what your trying to stop?
As mentioned you could prevent them from running the exe on their machines -- but there are 3rd party remote desktop clients they could run. Or for that matter why does it have to be remote desktop - they could just vnc to boxes outside your network, etc..
The details of exactly what your users are doing that you want to stop would be most helpful for us to suggest ways to prevent them from doing it.
If the issue is users having remote control of PCs outside of your network then outgoing firewall policies will need to be put in place. But again, there are specific questions and answers needed.
^ and it does not take a rocket scientist to figure out that if you block outbound access on 3389, to just have the machine listen on another port -- say 80 or 443 for remote desktop connections.
Trying to block users from access to things outside of your control is a uphill battle to say the least, its like trying to block spam.. As soon as you block one thing, they figure out a new way to get it paste the filters, etc.
Very true, it can get condeluded when talking about blocking outbound traffic. It is very easy to change the port RDP uses. It is of course still an option if he wanted to take that route.
Really the only options I see are:
1. Denying users from using Terminal Services via AD. Applies only in your environment.
2. Block all outbound traffic with the exception of legitimate ports. This could be very maintainence intensive and could get very condeluded, but could also work.
3. Block the mstsc.exe from ever executing in the first place. This would without a doubt stop RDP access regardless of what PC they are connecting to. However other forms of remote control could be used as stated using different ports.
So perhaps a combination of these could best suit you.
Sorry for the long delay.
I've blocked the terminal services in AD, several days on, this had made no difference.
We're using SBS2003, so dont have ISA server to have real control over outgoing ports etc.
Whats the easiest way to block the mstsc.exe in GPO?
I've never made any software restrictions before, so in simple terms would really help :)
If this is not working there's something wrong and I'd suggest you resolve it in case they work around the software restriction policy.
The Deny restriction applies to the user account that is being used to connect and not to the user launching the terminal services session, could that be the problem?
  barteh said:
i've gone to:
User Configuration\Administrative Templates\System
"dont run specified Windows applications" = enabled
and added: mstsc.exe
Doesn't that policy just compare a filename and/or its path to block the specified EXE? If so, couldn't a user just copy the file elsewhere (and/or rename it) and run it from there?
quite possibly.
What your saying is:
So in AD i tick the deny box which says Bart cannot use Term Services, but so long as I log into another machine with a different account Its letting me?
I've tried the .exe i'll just wait and see what happens.
Scenario for how it works:
Admin creates AD account Bart2, default is allow term services
Admin edits AD account Bart1, deny term services
Bart1 logons on to pc1 opens mstc and attempts to remote desktop pc2
pc2 asks pc1 for a logon
bart specifies his logon (Bart1)
pc2 checks the ad to see whether Bart1 is allowed access, then denies him access
Bart1 tries again:
bart1 specifies Bart2
pc2 checks the ad to see whether Bart2 is allowed access, then allows him access
So basically the check is all about whether an account is allowed to complete a connection and logon to a remote desktop, not whether an account is allowed to attempt a connection.
If the accounts are setup properly, this should work perfectly well as the user won't know the credentials for other accounts so the restriction works. Restricting the exe and preventing them from launching the client is a really poor workaround except for when the computers they are trying to access are not within the organisation's control (like home pc's over the internet) which is when a firewall with outgoing control should be used.
Sorry bobba, I think I should have explained in more detail earlier.
The Machine the user is connecting to is a home machine.
And like I mentioned earlier, we dont have ISA so we dont have that sort of control, and the admins do use RDP ourselves, so I dont want to completely disable it.
Sounds like you need something like the following:
software restriction policy:
Block the filename of MSTSC
Block the hash values of the various versions of MSTSC
Prevent it from applying to local admins
(if your troublesome users don't have them, use GPO security filtering if they do)
Articles to help:
MS Howto
Tutorial
Those are the technical means of controlling it, the organisation should also have a computer/internet usage policy as well so that they have to consciously break the rules to do something like this and if they do a discipline procedure can be applied.
    • And they are both to blame. SEO optimisation and the knowledge panel killed web search. Both companies knew what they were doing. Now an interactive/dedicated knowledge panel is the front and centre of AI search, with websites simply being a back end to feed data to these tech giants. Don't need to pay ad money to websites if users dont visit them in the first place. https://arstechnica.com/ai/202...site-clicks-by-almost-half/
    • People yearn for the good old days of IRC and truly open Internet, yet are dismissive of modern solutions like ActivityPub (which Mastodon pioneered) and Matrix. Make it make sense.
    • AI judges learn new tricks to fact-check and code better by Paul Hill Image via Pixabay AI researchers and developers are increasingly turning to large language models (LLMs) to evaluate the responses of other LLMs in a process known as “LLM-as-a-judge”. Unfortunately, the quality of these evaluations degrades on complex tasks like long-form factual checking, advanced coding, and math problems. Now, a new research paper published by researchers from the University of Cambridge and Apple outlines a new system that augments AI judges with external validation tools to improve their judgment quality. This system aims to overcome limitations found in both human and AI annotation. Humans face challenges and biases due to time limits, fatigue, and being influenced by writing style over factual accuracy while AI struggles with the aforementioned complex tasks. The Evaluation Agent that the researchers created is agentic so it can assess the response to determine if external tools are needed and utilizes the correct tools. For each evaluation, three main steps are passed through: initial domain assessment, tool usage, and a final decision. The fact-checking tool uses web search to verify atomic facts within a response; code execution leverages OpenAI’s code interpreter to run and verify code correctness; and math checker is a specialized version of the code execution tool for validating mathematical and arithmetic operations. If none of the tools are found to be useful for making judgments, the baseline LLM annotator is used to avoid unnecessary processing and potential performance regression on simple tasks. The system delivered notable improvements in long-form factual checking, with significant increases in agreement with ground-truth annotations across various baselines. In coding tasks, the agent-based approach significantly improved performance across all baselines. For challenging math tasks, the agents improved performance over some baselines, but not all, and overall agreement remained relatively low at around 56%. Notably, the researchers found that in long-form factual responses, the agent’s agreement with ground-truth was higher than that of human annotators. This framework is extensible, so in the future, other tools could be integrated to further improve LLM evaluation systems. The code for the framework will be made open source on Apple’s GitHub, but it isn’t up yet.
    • https://www.neowin.net/news/tags/mastodon/ In short: Federated Twitter (X)
    • Collaborator
      fernan99 earned a badge
      Collaborator
    • Collaborator
      MikeK13 earned a badge
      Collaborator
      Alexander 001 earned a badge
      Antonio Barboza earned a badge
      140
      129
