[SQL] Query statement help
Hello all. I have a table as the following.
| ID | Title |
G1   |  A
G1   |  B
G1   |  C
G1   |  D
G2   |  E
G2   |  F
G2   |  G
I would like to get results like this.
| ID | Title |
G1   |  A
	 |  B
	 |  C
	 |  D
G2   |  E
	 |  F
	 |  G
I did manage to get the desired results but I had to make two queries which are:
Q1 - SELECT DISTINCT ID
FROM table;
Q2 - SELECT Title
FROM table
WHERE ID = 'ID';
And within the loops to display the output so it would be like:
while fetch Q1 results {
   print 1 row of Q1;
   (Q2 Statement)
   while fetch Q2 results {
	  print Q2 results;
Is there a single query statement that I can use instead? Thanks in advance.
https://www.neowin.net/forum/topic/663044-sql-query-statement-help/
2 answers to this question
Ive never seen anything that might do this as far as just using a query. I dont understand the reasoning behind wanting to do it this way either :no:
If its just for display purposes youll probably need to use PHP or something to group them together and output them how you want. I would probably put them all into a multi-dimensional array with the ID being the top level and looping through each of the items for the output.
$query = "SELECT ID, Title FROM table ORDER BY ID ASC";
$result = mysql_query($query);
while($row = mysql_fetch_array($result){
	$topLvl[$row['ID']][count($topLvl[$row['ID']])] = $row['Title'];
// Then you can kind of reverse engineer to get what you want.
foreach($topLvl as $ID => $arrTitles){
	echo "<b><u>$ID</u></b><br>\n";
	foreach($arrTitles as $num => $title){
		echo "$title<br>\n";
	echo "<br>\n<br>\n"
that should return something like
G1
A
B
C
D
G2
E
F
G
Not quite the same but it can be formatted how you want fairly easy.
SELECT * FROM TABLE ORDER BY ID, TITLE
CurrID = 0
if(CurrID != RowID)
print heading
CurrID = RowID
print row
Should work?
    • Windows 11 24H2 gets big feature update with improved Settings, new BSOD, and more by Taras Buria Microsoft has released a big new feature update for Windows 11 version 24H2. Today's optional release is available as KB5062660 with build number 26100.4770, and it adds plenty of new features, including agentic search in Settings on Copilot+ PCs, Quick Machine Recovery, Recall for users in the European Economic Area, new Click to Do actions, File Explorer improvements, and more. Here is what is rolling out gradually: [Recall] New! Recall is now available in the European Economic Area (EEA). For more info, see Retrace your steps with Recall. In the EEA, Recall supports exporting snapshots to share with trusted third-party apps and websites. When saving snapshots is turned on for the first time, a unique Recall export code appears. This code is required to decrypt exported snapshots and is shown only once during initial setup. Microsoft doesn’t store or recover this code. To export, go to Settings > Privacy & Security > Recall & Snapshots > Advanced Settings and authenticate with Windows Hello. Choose to export past snapshots (from the last 7 days, 30 days, or all) or start a continuous export. Third-party apps can access exported snapshots only when both the export code and folder path are provided. If you lose or compromise the export code, reset Recall to generate a new one. New! For all Recall users worldwide, you can now reset Recall and delete all its data. Go to Settings > Privacy & Security > Recall & Snapshots to find a new advanced settings page. There, you’ll see a reset button that deletes all your snapshots and restores Recall to its default settings. [Click to Do] New! Practice in Reading Coach is a new Click to Do text action that helps you improve reading fluency and pronunciation. Select text on your screen, choose Practice in Reading Coach, and read the text aloud. Reading Coach gives you feedback and shows where to improve. To use this feature, install the free Microsoft Reading Coach app from the Microsoft Store. New! Read with Immersive Reader is a new text action in Click to Do that displays text in a focused, distraction-free environment. It helps improve reading and writing for all skill levels and abilities. You can adjust text size, spacing, font, and background theme, have text read aloud, break words into syllables, and highlight parts of speech. The picture dictionary shows images for unfamiliar words. To use this feature, install the free Microsoft Reading Coach application from the Microsoft Store. New! With the Draft with Copilot in Word text action, you can quickly turn any recognized text into a full draft. Whether it’s a sentence in an email or a snippet on your screen, press Win + Click on the recognized text, then select Draft with Copilot in Word. No more blank pages. No more writer’s block. Just momentum. To use “Draft with Copilot in Word” a Microsoft 365 Copilot subscription is required. New! Click to Do on Copilot+ PCs now supports actions through Microsoft Teams. When you select an email address recognized by Click to Do on your screen, you can choose to send a Teams message or schedule a Teams meeting. These options make it easy to ask a question or set up time to talk without interrupting your workflow. [Settings] New! The new agent in Settings is part of the Copilot+ PC experience and is designed to address one of the most common frustrations: finding and changing settings on your PC. You can describe what you need help with, such as “how to control my PC by voice” or “my mouse pointer is too small,” and the agent will suggest steps to resolve the issue. The agent uses AI on your PC to understand your request and, with your permission, can automate and complete tasks for you. This experience is rolling out to Snapdragon-powered Copilot+ PCs, with support for AMD and Intel™-powered PCs coming soon. It currently works only if your primary display language is set to English. New! On non-Copilot+ PCs, the Settings app now shows the Search box at the top center to make searching easier and more consistent. Fixed: If your PC is set to ‘Do nothing’ when you close the lid (under Settings > System > Power and Battery) and the Settings window is left open when you close the lid, reopening the lid might cause the Settings window to stop responding. It might become unresponsive to input or resizing and instead just display your accent color. Fixed: Settings might stop responding when you try to save Wi-Fi network credentials. [Windows Resiliency Initiative] The following changes are part of the Windows Resiliency Initiative announced at Ignite 2024: New! Quick machine recovery is now available. When enabled, it automatically detects and fixes widespread issues on Windows 11 devices using the Windows Recovery Environment (WinRE). This reduces downtime and avoids the need for manual fixes. If a device experiences a widespread boot issue, it enters WinRE, connects to the internet, and Microsoft can deliver a targeted fix through Windows Update. IT admins can enable or customize this experience for their organization through the Intune Settings Catalog UI using the RemoteRemediationCSP. There is also a dedicated quick machine recovery settings page available under System > Recovery > Quick machine recovery. Today, it’s enabled by default for home users. New! A more streamlined interface appears during an unexpected restart. This updated design aligns with Windows 11’s visual style and helps you return to work faster. The screen displays a more readable layout while keeping the technical details visible. This screen appears with a black background. [Start menu] New! We are adding a Boolean option to the Configure Start Pins policy to allow admins to apply Start menu pins once. This means that a user will receive admin pins on day 0 but can then make any changes to their Start pinned layout and have those changes safeguarded. These changes can be optionally applied through the existing configuration Service Provider (CSP). [Snap] New! Improvements make it easier to learn and use Snap in Windows 11. Inline messages now appear when you accidentally open the Snap Bar by dragging an app to the upper center of your desktop or open the Snap menu by hovering over the Minimize or Maximize button. These messages provide helpful tips on Snap app windows and show keyboard shortcuts. [Windows Search] New! Windows Search settings are now easier to find. Instead of two separate pages for settings (“Search permissions” and “Searching Windows”), you can find everything in one place under Settings > Privacy & security > Search. This new page has a modern look and a better layout, so you can quickly view and manage all your Windows Search settings. [Input] New! The Gamepad layout of the Windows touch keyboard now includes enhanced controller navigation and improved focus handling for child keys, menus, word suggestions, language switching, and settings. A new Gamepad keyboard, designed for gaming, also supports PIN sign-in on the Windows lock screen. It offers controller shortcuts for quick PIN entry and full navigation for those who prefer not to use shortcuts. [File Explorer] Fixed: If you open More options ​​​​​​​ in File Explorer to view the full list of folders for the current path, the dropdown menu might not display completely, making the bottom part inaccessible. Fixed: File operation progress dialogs might stop appearing when displayed from apps. Fixed: Syncing more SharePoint sites to File Explorer might slow performance when navigating folders or opening the context menu. This can also affect how quickly files launch. [Desktop icons] Fixed: If you have an app pinned to your desktop and it updates, the app icon might not display correctly and instead show a white page. [Notifications] Fixed: When you select a Windows notification, it might not bring the related app to the foreground as expected—for example, this can happen with Outlook notifications. Here are the changes that are available to all users right here and right now: [Authentication] Fixed: This update addresses an issue that affects the Local Security Authority Subsystem Service (LSASS). LSASS might stop responding during machine password changes with specific audit settings. [File Explorer] Fixed: File Explorer Home might unexpectedly only display a single folder (for example, Desktop), rather than the expected content with recent files and more. [File system] Fixed: This update addresses an issue in the Resilient File System (ReFS) where using backup applications on large files could occasionally result in system memory becoming fully exhausted. [Graphics] An issue where external graphics cards connected through Thunderbolt weren’t always recognized in some cases. [Input (know issue)] Fixed: An issue when using the Microsoft Changjie IME (input method editor) for Traditional Chinese might cause problems such as not being able to form or select words, unresponsive spacebar or blank key, incorrect word output, or a broken candidate window display. This can occur after installing KB5062553. Fixed: This update addresses an issue that affects Phonetic input methods, including the Hindi Phonetic Input keyboard and the Marathi Phonetic keyboard, which might not work correctly after installing KB5062553. [Stability issue] This update addresses an issue observed in rare cases after installing the May 2025 security update and subsequent updates causing devices to experience stability issues. Some devices became unresponsive and stopped responding in specific scenarios. [Windows Firewall] Fixed: This update addresses an issue found in Event Viewer as Event 2042 for Windows Firewall with Advanced Security. The event appears as "Config Read Failed" with the message "More data is available." For more information about this issue, see "Error events are logged for Windows Firewall" in the Windows Health Dashboard.​​​​​​​ You can download KB5062660 by heading to Settings > Windows Update and clicking "Check for Updates." The update is also available via the Microsoft Update Catalog.
    • With all this development of their web-apps, wonder when they'll begin the same stupid move of replacing their native Desktop apps with the web-based trash like they're doing with Outlook...have a feeling that's not far off.
    • In about:config, ensure these three are set to false: browser.tabs.groups.smart.enabled browser.tabs.groups.smart.optin browser.tabs.groups.smart.userEnabled
    • Excel for the web finally gets crucial data refresh feature by Usama Jawad Microsoft Excel is a very popular spreadsheet tool used for a variety of purposes in both personal and enterprise use, including data crunching, reporting, and analysis. Microsoft regularly adds new features to the software, including easier edit access and a revamped UX to fetch data from external sources. Now, the company has made some further improvements in the latter area. Excel for the web has recently netted a very important feature: the ability to refresh authenticated data sources leveraging Power Query. Previously, if you wanted to refresh an external data source in Excel for the web, you would need to download the file locally and apply the refresh there before syncing it to the web version or uploading it there. With the latest enhancement, you can simply apply Refresh All through the Data tab or refresh individual data sources through the Queries pane. Currently, refreshes are limited to 1,000 connections per user, and once you trigger a refresh, you may be prompted to enter your credentials to the authenticated data source, which includes SharePoint, SQL Server, Web API, and more. You can continue working on other aspects of your workbook while the refresh completes. In the same vein, it is now possible to view and manage data source credentials for queries authored by Power Query through the Data > Data Source Settings tab. Users have the ability to view, delete, and modify credentials at a global level or just for their current workbook. They will also be able to authenticate to a data source that already exists in the Excel workbook through the same tab. Both these capabilities are now available for all Excel for the web customers. Microsoft says that its future plans include the migration of the full-fledged Power Query experience from desktop to the web, but it is yet to share a public timeline.
    • Windows 10 KB5062649 fixes Extended Security bug, unresponsive systems, and more by Sayan Sen Microsoft has released today the non-security preview update (also known as the C-release) for Windows 10. The update, under KB5062649 and Build 19045.6159, fixes some major bugs including one for Extended Security Updates (ESU), unresponsive systems, Secure Boot, and more. Since this is a preview update for next month's Patch Tuesday it is an optional release. Microsoft says that users reported that the ESU wizard would not work correctly when they tried to use the option to extend support for Windows 10 for another year; this bug should be fixed now. The company has also fixed "stability issues" with this release as it resolves problems in the core file system. Affected users reported unresponsive systems since the May 2025 Patch Tuesday. There are other improvements as well. The full changelog is given below: ​​​​​[Extended Security Updates] Fixed: An issue impacting the Windows 10 Extended Security Updates (ESU) enrollment wizard. Some users experienced a problem where clicking “Enroll now” caused the wizard window to open, begin loading, and then close unexpectedly. This occurred due to incomplete app registration, which prevented the wizard from loading correctly. This update addresses that issue to ensure a smoother enrollment experience. [Mobile Operator Profiles] Updated: Country and Operator Settings Asset (COSA) profiles. [Secure Boot] New! Adds the ability to deploy SKUSiPolicy VBS Anti-rollback protections through the Secure Boot AvailableUpdates registry key. [Core File Systems] Fixed: An issue observed in rare cases after installing the May 2025 security update and subsequent updates causing devices to experience stability issues. Some devices became unresponsive and stopped responding in specific scenarios. [Input] Fixed: A known issue with the Microsoft Changjie Input Method. Users were unable to select words after a recent update. Fixed: A known issue when searching for an emoji in the emoji panel. After a recent update, the search always returns no results. Fixed: An issue in which phonetic input methods, including the Hindi Phonetic Input keyboard and Marathi Phonetic keyboard do not work correctly after a recent update. You can find the official support article here on Microsoft's website.
    • Community Regular
      vZeroG went up a rank
      Community Regular
    • Collaborator
      Snake Doc earned a badge
      Collaborator
      131
      122
