[C#] Problem with double-click on ListBox item
Hi there,
I have a ListBox with a few items and at sometimes, when the ListBox only has a couple of items, you'll see a blank area after the last item because there are no more items to fill the ListBox.
Now, I've implemented the MouseDoubleClick event to get the index of the double-clicked item in the ListBox like this:
private void listNotes_MouseDoubleClick(object sender, MouseEventArgs e) {
	int noteIndex = listNotes.IndexFromPoint(e.Location);
	// DO SOMETHING ELSE...
However, if I double-click on that blank area, noteIndex will have the index value of the last item on the list.
I need to ignore this behavior. Any suggestions?
21 answers to this question
You are right about something, SelectedIndex is much simpler. I don't know why I didn't use it in the first place... However, it does not solve the problem.
Double-clicking the blank area will return the index from the last item in the ListBox. Forget for a minute about the double-clicking, because that's not probably the problem. Let's say that event is not implemented, when you single-click any item in the ListBox, that item will be selected, but if you single-click on the blank area below the last item, that last item will be selected.
Conclusion, the last item is being selected when I click on the blank area, that's what I want to avoid...
If I click the blank region in a listbox the last item is not selected and the selectedIndex returns -1. If there is a item selected from a previous single click then that selected index will be returned because it is the item selected, and the double click is based on clicking the listbox.
ways around would be to clear the Selected Items before you get the selectedIndex. make a copy of them before, and then re-assign them after you get the selectedIndex from the mouseClick.
That way, no interference from other events should be a problem.
I don't understand what you are saying.
I cleared the selected items, clicked the blank area and the last item was selected...
One thing I haven't told you and maybe that's where is the problem... I'm using the KryptonListBox from the Krypton Toolkit, not the ListBox from Windows Forms. Maybe I should post this on the Krypton forums...
Thanks for all your help :)
From what I understand, you were saying that clicking a the blank area in the Listbox selects the last item. I can't recreate this behaviour using the 2008 Windows Forms version. Whether the Krypton one adds this is something to investigate.
The main problem I understand is that the double click event works, just that other event handlers and functions are getting in the way, such as single click, ect. To rectify this the only way I can think of would be to save the state of the object before the click, then clear down all selected properties, and just look at the one from the MouseEventArgs.
Then you can copy the data back in. That way, any items selected before the double click will be ignored. Of course this is catering for a very small number of possibilities..
I don't really know what to say...
Please take a look at the attached solution. It's a very simple C# app with just the KryptonListBox. Open it, press F5 and click on the blank area. You'll see the last item getting selected...
WindowsFormsApplication1.zipFetching info...
Not played with C# for a while, but wouldn't you be able to hook into the ondoubleclick event on the items themselves, thus avoiding this issue?
I tried to do this earlier but I don't its possible in C#. Played with the attached solution as well and can't really get anywhere with it.
Oh its an custom made listbox. I played with it and the same happens so I changed "SelectionMode" to None and it works... and it doesnt. MouseDoubleClick event doesnt work only SelectedIndexChanged. I guess the creator of the control left some things out.
I'm not sure what exactly is going on, but I tried a simple project with a listbox, a few items and subscribed to the MouseDoubleClick event, and this worked fine;
MessageBox.Show(listBox1.IndexFromPoint(e.Location).ToString());
Which is what you were using earlier, and it works on my machine. Regardless of previously selected items, if you double click in the extra space in the listbox (the area not occupied by a list item), it successfully returns -1 :s
The author of Krypton Toolkit answered me with this:
  "Phil Wright" said:
I think the difference in behavior is because the Krypton list box is owner drawn and your standard one is not. But you can use code to work out the answer. Compare the returned item with the display rectangle of that item to ensure it really is under the mouse...
		private void kryptonListBox1_MouseDoubleClick(object sender, MouseEventArgs e)
			int noteIndex = kryptonListBox1.IndexFromPoint(e.Location);
			if ((noteIndex >= 0) && (!kryptonListBox1.GetItemRectangle(noteIndex).Contains(e.Location)))
				noteIndex = -1;
That would work for the MouseDoubleClick but I also have some buttons that perform actions on the selected listbox item. A single mouse click on the blank area also selects the last item. I also need to ignore this behavior... I've been trying a couple of things around the code above but haven't managed to do so, any ideas?
I can override some if I created a class based on KryptonListBox, actually, already tried this but couldn't find a method that would help me with this problem, or I'm seeing how could I use that method to work around the problem...
    • Gemini CLI brings AI smarts to your Firebase terminal experience by Paul Hill Google has added its Gemini AI model directly into the command-line interface of Firebase Studio, its cloud-based IDE that uses AI to help with projects. The Gemini Command Line Interface (CLI) means that developers can expand past using AI for code, they can now also use AI for content generation and research without leaving the IDE. Gemini CLI comes with free usage tiers (60 model requests per minute, 1,000 requests per day with a Google login), it offers advanced AI features, and includes integrated Google Search for real-time content. Gemini CLI is also open source so it can be customized and accepts contributions. Accessing the Gemini CLI within Firebase Studio is straightforward, just press “Code view” in the top-right. From there, open up the terminal from the burger menu then select Terminal and New Terminal. Then in the terminal, type gemini and go through the setup, you can just press enter twice to get started. Out of the box, you’ll be able to get started with Gemini 2.5 Pro by just typing a query and pressing enter. There is also a non-interactive mode that’s useful for scripting and automation. To use it you use the –prompt or -p flags followed by your query wrapped in quotes, for example: gemini -p “What is the capital of France?” In this mode, Gemini CLI automatically closes after completing the request. During setup, there was the option to choose a theme. If you ever want to change it or look at other settings such as usage states, tool access, or checkpointing, you can edit them via .gemini/settings.json. You can also add API keys or choose different models in .env and you can using GEMINI.md to provide project-specific context, instructions, and coding styles in Gemini for a more tailored response. With Gemini CLI, you can have it explain code, refactor code, debug errors, and summarize information. It’s as simple as typing explain [file], refactor , debug “Error message”, or summarize “topic”. There are also built-in commands for managing the session such as /help for a command list, /chat to save and resume conversations, /tools to see available tools, and /restore to undo tool-made file edits. Firebase Studio, in true Google fashion, is a cloud-based IDE used in your web browser, making it excellent for weaker computers. To get started, you can head to the Firebase website. From there, tap Studio in the top-right.
    • I would prefer local ai over online ai on some tasks . They are good enough for tasks like artificial voice , image editing , text corrections , tagging etc . Local AI on Windows Photo editor is impressive for example . There are probably many other Ai that we could run on simple pc with GPUs .
    • oh look, we are under the control of the U.S again, is it not about time we as a country did this ourselves if they want it, not rely on greedy U.S. tech companies? We are capable of doing so as a country. I hate how the U.K have gone with no industry like we used to have and relying on other countries. Maybe we should follow Trump words, and make Britain great again and stop bending over to please Trump and other countries. Our government is Trumps puppet. I know we need to co-operate on some things, but come on.
    • Actually I see no problem is notifying readers in advance. The post author mentioned that it'll be available on July 22.
    • We can actually disable this new AI powered tab groups suggestion feature. https://www.askvg.com/enable-o...mart-tab-groups-in-firefox/
      MIghty Haul earned a badge
    • Collaborator
      KD2004 earned a badge
      Collaborator
      ataho31016 earned a badge
      Delahenty Machinery earned a badge
      140
      127
