rockman56 Posted March 27, 2003 Share Posted March 27, 2003 i dunno what happened but i no longer can install any programs... installshield loads up but then just freezes... anyone know what's going on? Link to comment https://www.neowin.net/forum/topic/68752-problem-w-installshield/ Share on other sites More sharing options...
0 BoondockSaint Posted March 28, 2003 Share Posted March 28, 2003 rockman56 said: i dunno what happened but i no longer can install any programs...installshield loads up but then just freezes... anyone know what's going on? Have you tried clearing your temp directory? IS has lots of problems if the windows temp directory has lots of files in it (not necessarily IS files either)... Link to comment https://www.neowin.net/forum/topic/68752-problem-w-installshield/#findComment-719216 Share on other sites More sharing options...
0 rockman56 Posted March 29, 2003 Author Share Posted March 29, 2003 i just tried clearing the temp files but it still doesn't work...thx anyways.. any other suggestions? Link to comment https://www.neowin.net/forum/topic/68752-problem-w-installshield/#findComment-722730 Share on other sites More sharing options...
0 DeleteMePlease Posted March 30, 2003 Share Posted March 30, 2003 delete the installsheid folder then reinstall the appz, it in program files. it worker for my friend when he had problem installing jkII Link to comment https://www.neowin.net/forum/topic/68752-problem-w-installshield/#findComment-725067 Share on other sites More sharing options...
0 rockman56 Posted April 11, 2003 Author Share Posted April 11, 2003 what do u mean reinstall the apps? installshield or the stuff i was trying to install in the first place? i deleted the installshield folder in program files but it still doesn't work... Link to comment https://www.neowin.net/forum/topic/68752-problem-w-installshield/#findComment-761752 Share on other sites More sharing options...
0 mikejd1 Posted April 11, 2003 Share Posted April 11, 2003 i had this problem a long time ago, did you "disable" any process in Services? Link to comment https://www.neowin.net/forum/topic/68752-problem-w-installshield/#findComment-761789 Share on other sites More sharing options...
0 rockman56 Posted April 13, 2003 Author Share Posted April 13, 2003 nope not that i know of... which processes are necessary for it to run? Link to comment https://www.neowin.net/forum/topic/68752-problem-w-installshield/#findComment-766384 Share on other sites More sharing options...
0 mikejd1 Posted April 13, 2003 Share Posted April 13, 2003 not sure, thats the thing. i disabled with good intension, byu reading articles, etc...once disabled, the install engines sucked nads. i reenabled some of them and it worked again, i cant think which it was though, sorry :( Link to comment https://www.neowin.net/forum/topic/68752-problem-w-installshield/#findComment-767043 Share on other sites More sharing options...
0 rockman56 Posted April 15, 2003 Author Share Posted April 15, 2003 @lebmike: that's ok...thanks anyways anyone else know how to fix this? Link to comment https://www.neowin.net/forum/topic/68752-problem-w-installshield/#findComment-772481 Share on other sites More sharing options...
0 nekrosoft13 Posted April 15, 2003 Share Posted April 15, 2003 i had the same problem about 2 months ago. you got windows xp right? if you do windows xp then you got problem with windows installter that is made by installshield. go to c:\program files\common files\ and delete the installshield folder (yes the whole thing). also delete all the files in the temp folder. the reason why you delete the installshield engine is, when you run a installer that was made with installshield it will reinstall the files that are required. Link to comment https://www.neowin.net/forum/topic/68752-problem-w-installshield/#findComment-772847 Share on other sites More sharing options...
0 rockman56 Posted April 16, 2003 Author Share Posted April 16, 2003 hmm...well i tried that but i still get an error... Error signature AppName: _ins5176._mp AppVer: 5.10.130.0 ModName: unknown ModVer: 0.0.0.0 Offset: 6c756765 Link to comment https://www.neowin.net/forum/topic/68752-problem-w-installshield/#findComment-775896 Share on other sites More sharing options...
0 nekrosoft13 Posted April 16, 2003 Share Posted April 16, 2003 hmm, i don't know then, it worked for me, when my installshield got messed up. Link to comment https://www.neowin.net/forum/topic/68752-problem-w-installshield/#findComment-775961 Share on other sites More sharing options...
0 rockman56 Posted April 19, 2003 Author Share Posted April 19, 2003 thanks anyways :happy: ...so...anyone else? Link to comment https://www.neowin.net/forum/topic/68752-problem-w-installshield/#findComment-784476 Share on other sites More sharing options...
0 urumartin Posted May 8, 2003 Share Posted May 8, 2003 I have similar problems with all installers made by WiseInstaller. the installer just cannot install the programs............... does anyone have cure for this? Link to comment https://www.neowin.net/forum/topic/68752-problem-w-installshield/#findComment-842646 Share on other sites More sharing options...
0 SuperJediMedia Posted August 18, 2004 Share Posted August 18, 2004 (edited) I NEED answers on this as well!!! I am having hell of time with my ATI multimedia center :angry: as well as other Installshield apps. :angry: Quote i had this problem a long time ago, did you "disable" any process in Services? Can someone just tell us what service is needed? When I uninstall ATI MMC, I always get stuck!!! For the difference in Task Manager... I got 3 IDriver.exes running, 2 msiexec.exe running, a regsvr32.exe running. maybe 1 extra svchost, but I am not sure Regsvr32 takes up a lot of CPU My guess is Installshield needs a fix, not the MMC! Edited August 18, 2004 by JediXAngel Link to comment https://www.neowin.net/forum/topic/68752-problem-w-installshield/#findComment-584383324 Share on other sites More sharing options...
0 Hexum Posted August 18, 2004 Share Posted August 18, 2004 Do either of you have SP2 installed on your pc? If so, you may want to look at the list of programs Microsoft released that may have problems with SP2. Installsheild is on that list :/ Here is link to the Knowledge Base article: http://support.microsoft.com/default.aspx?...ct=windowsxpsp2 Link to comment https://www.neowin.net/forum/topic/68752-problem-w-installshield/#findComment-584383867 Share on other sites More sharing options...
rockman56
https://www.neowin.net/forum/topic/68752-problem-w-installshield/Share on other sites
15 answers to this question
