- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
no name
Need help with partition magic... how to create a new partition while windows xp installed?
//Note. I use windows 2003, and i need to do it for my friend. I can't even have a screen shot for now so please explain as thorough as possible and many thanks! :)
https://www.neowin.net/forum/topic/71121-help-partition-magic/Share on other sites
12 answers to this question
