Problem with Cydia (Jailbroken Iphone) HTTP:/ 1.1 404 not found.
Hey everyone,
every time I try to install anything via Cydia, I get the error HTTP:/ 1.1 404 not found.
Edit: When I switch to just 3G I get "NetDB: Open nodename nor servername provided or not known". For both situations it lists the server name as http://cydia.ispazio.net
This happens consistently, anytime I try it gives the same error. I'm currently connected to my wifi, and it's working on my dads iphone, strange.
If anybody could help that would be great!
404 not found means the files don't exist. Have you tried reloading your sources? This used to happen to my bro on his iPhone 2G and reloading fixed the problem.
  Marshalus said:
It worked this morning, then stopped, then about an hour ago it worked... now it's broke again. It looks like it has a problem downloading the gpg key.
It seems that the iSpazio repo is having their own share of problems.
To the OP, does any other source act like this or do they all work as they should? Ignore my PM response now that you provided some more detail.
edit:
  Rob2687 said:
Not working for me either...
Again this must be from iSpazio and not from Cydia so I don't think you have any problem unless this happens to any other source you have i.e. bigboss or any others you have
  Steveca said:
Use quick pawn leave your iPhone update at 2.2 then you have no problems
His jailbreak is not the problem, its from the Cydia repo. How is it his problem if iSpazio is down?
  • 2 years later...
Hey guys! I had a same issue a few days ago. Found a solution and hv written a step-by-step guide on my personal blog here http://jaxov.com/2011/04/fix-cydia-http-404-not-found-cached-failure-error/ You need to delete some files by SSH'ing into your iDevice. It works 100%
PS: If this message counts under spamming, delete it.
I was actually going to post that. That worked for me before when my cydia was extremely slow. Deleting the files and relaunching Cydia fixed the problem.
