Routing Same Port Traffic to Different VMs based on Subdomain?
I have a few friends that I help out with testing different web sites / server setups before going live on their own site/server. To do this, I have set up multiple Virtual Machines on a Mac OS X Client Host (using VMware Fusion). The problem I run into is how to ensure traffic is routed to the appropriate Virtual Machine based on the Subdomain used. For example...
Let's say I have set up the subdomain vm1.domain.com on a Linux Guest Virtual Machine. What I know is that Port 80 would come over the Internet into the Airport Extreme router, where all Port 80 traffic is sent to a DNS Server (I assume) to translate which subdomain needs to be routed which Internal/Private IP Address. In this example, the DNS Server sees vm1.domain.com and knows to send it to 10.0.22.100.
My question is this. Is this the correct process? If so, would it be wise to run a DNS Server on the Mac OS X client or use another Virtual Machine just for DNS routing.
If this process is incorrect, what is the best way to set this up with the equipment that is available to me (as shown in the graphic)?
The DNS server you are talking about is all routed through your internet router (which sends the requests to your ISP DNS servers), which then sends back to the original requester (the pc or vm within the network).
If you wanna use the same port on different vm's to serve some application then you will need more than one static IP from your ISP. As more than likely you will have only 1 IP address assigned to your account.
Once you have more IPS from your ISP, then you can go ahead and assign these IPs to your VM's and the forwarding of ports should be alright (you might need to configure this on your internet router, so that it routes the right ports to the correct device/IP on the network).
Well... poo. I was hoping THAT wouldn't be the answer. Since this is just for testing more than anything, I guess I'll just use different port numbers for each server as there is no way I can afford multiple IPs for just test servers. Real bummer.
Anyone wanna give a second opinion? :)
There is no need for other "opinions" that was the correct answer.. To send the same port to muliple IPs behind a nat, you need multiple public IPs.
Now depending on the application that is no big deal, and your private sides can all listen on the same port... Lets say for example it was RDP.
your public IP is 24.1.1.1, your privates are 192.168.1.100, .101, .102
On your router you could forward say 3389 to .100, 3390 to 3389 on .101 and 3391 to 3389 to .103 -- That is if your router supports this, any decent one would. If not you would have to change each vm to listen on the different ports for the application.
So somone on the outside that wanted to connect to machine 1 for rdp could just use normal 3389 port, but if wanted to connect to machine 2 he would go to 24.1.1.1:3390 which the router would send to 192.168.1.101:3389
But wanting to setup multiple machines to provide the same service on the same port to the public.. Sorry You would need multiple public IPs, there is no way to tell DNS anything about what port to connect to, etc.
One option you would be able to use is setting up Apache on the host machine or one of the guests) to proxy the requests to the relevant private IP, open up port 80 to that instance of Apache, and users outside would know no difference.
    • Microsoft changed recall to opt-in some time ago, which seems to still be the case. I personally feel like that is the right move for something like this. You are right, settings that turn themselves back on after an update is totally unacceptable; its weird how that only happened with privacy and advertising related settings...
    • I have a Tab S9 FE and a Tab A9+ which is a lot less expensive. I much prefer the TabA9+. 1. Its display is more landscape while that of the S9 FE is more boxy. 2. They both drain battery at about the same rate of between 7% and 9% an hour depending on how I use them 3. The Tab A9+ charges a lot faster than S9 FE, The S9 FE is better at handling memory, It is faster. They both have 8GB. The TabA9+ does a lot better at handling memory on Android 15, One UI 7.0 than it did on Android 14, One UI 6.1
    • Following rough launch, Splitgate 2 is going back to beta as studio announces layoffs by Pulasthi Ariyasinghe The sequel to the free-to-play arena shooter Splitgate was released just a couple of months ago alongside a surprise Battle Royale mode, but it doesn't look like the launch has gone too well for the studio, 1047 Games. In a lengthy social media post, the developer revealed that it is making some major changes within the company that will also affect its games. The studio said that it agrees with the community regarding Splitgate 2 launching too early with rushed features. Because of this, the title is returning to its beta state. While Splitgate 2 will remain playable, the studio will be deep in development reworking the title behind the scenes until at least early 2026. The soon-landing Season 3 content update is still planned for release. "We're returning not just to our roots in what we build, but in how we build it – with you," said the company. "That means more playtests, more surveys, more listening, and truly being community first. Our goal is to combine the DNA of the first game with the best improvements from the second." The studio also revealed that this shakeup means that it had to cut some team members from the studio. It didn't give an exact number for the roles being cut but said that "we hope to bring them back when we can." In the same vein of keeping costs low, 1047 Games will be shutting down the servers for the original Splitgate within a month's time. "While we'd love to keep servers online indefinitely, it's cost us hundreds of thousands of dollars over the past couple of years, and we have to prioritize our team," added the studio. It said that offline play or peer-to-peer matchmaking for Splitgate are being explored for fans to keep playing, but nothing concrete about these potential options was announced today.
    • It sounds like you are referring to the hidden div scandal, which due to an architectural limitation on Edge prevented hardware acceleration, but of course Google denied that it was specifically intended to break Edge, which of course I don't believe. Google is known for that kind of evilness. The hidden div was also being served to Chrome in that case, but it had a different method that didn't break hardware acceleration.
    • I guess we can agree to disagree. I had the completely opposite experience, and not just that it annoyed me, I was frequently unable to use the sites I visited regularly.
    • Community Regular
      vZeroG went up a rank
      Community Regular
    • Collaborator
      Snake Doc earned a badge
      Collaborator
      133
      122
