How to connect to serial port on switch without a PC serial port
Hey all,
I have a question here about a Dell PowerConnect 5224 switch I received not too long ago. I want to set it up and configure it in my office and to enable the management interface to it. However at the moment I have no way to connect to the serial port on the switch. My computers all are legacy free in that they don't have LPT or DB9 Serial ports, only LAN and USB.
I did do some searching in my massive stockpile of parts and found I have a USB to RJ45 cable as well as a RJ45 (female) to DB9 (female) adapter which all fits perfectly to the DB9 port on the switch. However when I use hyperterminal in XP, connecting on Com1 and COM3, nothing happens. No response. I'm thinking these cables/adapters might not be the right ones. Is that correct or do I need something else cable wise?
How do I accomplish this??
Brad
Hello,
If you want to connect via a USB port then you will need a USB to RS-232C serial adapter, which contains a circuit board to convert the electrical signals between the two different types of interfaces. They are fairly inexpensive to purchase.
Regards,
Aryeh Goretsky
http://docs.us.dell.com/support/edocs/netw...4cb.htm#1099632
Connecting the Console Port
The switch provides an RS-232 serial port that enables a connection to a computer or terminal for monitoring and configuring the switch. This port is a male DB-9 connector, implemented as a data terminal equipment (DTE) connection.
To use the console port, you need the following equipment:
* A terminal or a computer with both a serial port and the ability to emulate a terminal
* A null modem or crossover RS-232 cable with a female DB-9 connector for the console port on the switch
You need a "null modem" cable -- so its unlikely that throughing together some adapters and cables will work.. The switch should of came with the cable.. If you have no computers with a serial port, then as suggesed buy a pic card or pcmcia card to provide you with one.
But out of the box you should just be able to connect to the web interface -- should you not? I see nothing in the docs about having to enable the web interface, etc.
By default the management IP would be using dhcp, so it will IP from your dhcp server - and then just connect a machine to any one of its switch ports -- they all default to vlan1 and you should be able to call up its web interface to manage it.
For my work I have to use RS 232 & RS 422 commands via a 9 pin port. What we use are KEYSPAN USB to Serial adapters. They include drivers for Windows and Mac, but you'll have to search for Linux, but they do exist.
    • Toshiba's massive 22TB X300 PRO hard drive is 29% off by Taras Buria Toshiba is offering its highest-capacity X300 PRO hard drive at a new all-time low price, allowing you to save 29% or $171 on the massive 22TB drive. The X300 PRO hard drive lineup offers good performance, and it is rated for high yearly workloads, which makes it a great option for creative professionals or other tasks that require storing a lot of data. The X300 PRO is a 7,200 RPM conventional magnetic recording (CMR) 3.5-inch SATA 6Gbps internal hard drive with 512MB of cache, which is also paired with the Toshiba Cache Technology for improved real-time responsiveness during high-demand loads. It also has additional features for better reliability, such as ramp loading (heads rest to a side of platters to prevent damage when the drive is idling or powered down) and shock sensors. Toshiba claims that the 22TB X300 PRO is rated for up to a 300TB/year workload rate and 1 million hours of mean time to failure (MTTF). This makes the drive a good choice for workstations, multimedia systems, or network-attached storage. Additionally, each drive has a limited five-year warranty for additional peace of mind. 22TB Toshiba X300 PRO High Workload Performance HDD - $428.99 | 29% off on Amazon US This Amazon deal is US-specific and not available in other regions unless specified. If you don't like it or want to look at more options, check out the Amazon US deals page here. Get Prime (SNAP), Prime Video, Audible Plus or Kindle / Music Unlimited. Free for 30 days. As an Amazon Associate, we earn from qualifying purchases.
    • The 4060 is the weak 8-GB version. They should have done better.
    • This is an example of why it is so difficult to have a conversation with conservatives - they refuse to operate in good faith. You say "Those are not rights. Those were special treatments that were taken away that non-trans whatever didn't get." Which means you either failed to read any of the links I provided or you are lying. The very first link is about how the U.S. Military is firing trans people out of the military because they are trans and denying them retirement benefits. What other groups does the military treat this way that would support your assertion that they had been treated as special previously? Does the miliary routinely fire large numbers of its members and deny them retirement and was heretofore not doing that to trans people? I fail to see the logic in your argument.
      Jaclidio hoy earned a badge
      Yawdee earned a badge
      eugwalker earned a badge
      Ben Gross earned a badge
      chiptuning earned a badge
      178
      120
      wakjak
      108
