Need some basic help with Eclipse
Anytime I have to work with Eclipse I feel like I've been removed a leg and half of my fingers : handicapped. And yet at some point I'll have to be comfortable with the IDE (ie: by this summer - I'll have to work in Java mainly).
So aside from putting you in context, I have a precise question.
I have a homework to do, in Java. It must be done on Linux because the provided code includes bash scripts and the like, but Eclipse looks the same to me on Linux and Windows. So anyway. There are four .java files that come in a zip file, they are classes and one is the program with a main method. I want to use that as my "project" in eclipse (like projects in Visual Studio) : be able to edit the files, add new ones, debug the thing, run the thing, etc.
Now I've messed around and got it somehow running but I know I wasn't doing everything as I should. I created a new project in the workspace, click-and-dragged the files into the package, and started editing them. At some point though I realised the changes I made weren't taken into account, and I was somehow editing copies of the files that were not part of the project. A few copy-pastes fixed the problem but heck, that's not too professional.
So please give me a basic tutorial on how to accomplish this.
There I'll give you some Java code :
// MainProgram.java
public class MainProgram
	public static void main(String[] args)
		HelloWorld.printMessage();
// HelloWorld.java
public class HelloWorld
	public static void printMessage()
		System.out.println("Hellod!");
These are existing files, their name is indicated in comments. Please tell me step by step (I'm stupid, ok ?) how to compile and debug that code properly in Eclipse.
https://www.neowin.net/forum/topic/742140-need-some-basic-help-with-eclipse/
3 answers to this question
  Antaris said:
How are you adding existing files into Eclipse, are you using the Import option from the Project panel?
Drag-and-drop from a folder.
I've figured it out a bit better now, when I create a project I select "from existing source" (something like that) and select the folder containing the files. And it works. But I've still quite a lot of difficulty. When I go to the debug view and launch a debug session, I can put breakpoints but they don't work (and they're hard to see, tiny blue dots in the margin); all the debug commands I'd like to use (Step into, step over, resume, etc.) are greyed out in the menu. Running in debug is basically just like running normally, don't know why. I know I got it working before though.
I'm also confused as to what gets run when I click run, as I divided my project in two parts by creating two different packages each with a class containing a main method. What I do now is right-click the right class in the package explorer and select run from there, but it feels messy. Should I rather create a new project for each different program?
Edited by Dr_Asik
Eclipse has multiple Run Configurations - just hit the drop-down arrow next to the Run icon and you can create & select from your run configs. To get the debug options you just need to run in debug mode (small spider icon to left of Run in the toolbar).
    • ISTM from the article that the user was just out to get the developer for one reason or another. It may have had nothing to do with the software but the user just wanted to harm the developer in one way or another for some personal reason. They used the the project's Codeberg page to accomplish their goal.
    • ""Settings vs. Control Panel" - this has absolutely been fixed." - This is absolutely not fixed. Your personal experience may vary but still there is a clear division between two. "Error 0x80070643" - this issue never existed for Windows 11: https://learn.microsoft.com/en...(install-error-0x80070643). You can find similar cases for Windows 11; this is just example. Though with Windows 11, the issue is not so common like Windows 10. "UX inconsistencies" - This is terrible. And not just UX but UI as well. Windows 11 may work but it's not a good product. Hundreds thousands of engineering hours, billions of USD... This might be the only choice by force due to the jettisoning of Windows 10, however the end product for all those resources spent is simply not good. The real problem is lack of competition. Linux derivatives and MacOS unfortunately are not competitive.
    • Grab Motorola's Razr Ultra 2025 at 15% off and ditch your slab phone by Paul Hill Motorola is currently selling the Razr Ultra 2025 on Amazon at a discount of 15%, meaning you can pick it up now for $1,099.99 instead of the usual $1,299.99. This is a notable saving on a premium foldable smartphone, but it still remains a high-end purchase. Any Prime members out there can get free overnight delivery and if you have an old device to trade in, then you can get up to $725 in Amazon.com Gift Card credit that you can use towards your upgrade. One of the main perks of this device is that it’s universally unlocked, meaning you can use it on all major US carriers. It’s powered by the Snapdragon 8 Elite and comes with 16GB RAM and 512GB storage. With these specs, this device should be able to run any apps you throw at it. The Pantone Scarab color, a soft, velvety suede-like texture, is the result of a collaboration with the Italian brand Alcantara, known for its premium materials, giving the phone a very unique look. As a flip phone, you also get an intelligent and interactive external display that lets you access apps without opening your phone. Even with this external display, Motorola says you can expect over 36 hours of battery life and when you do need to recharge, you have fast charging. The main display on this device is 7 inches and features a Super HD resolution which is 2992 x 1224, the refresh rate is 165Hz. The external display has a resolution of 1272 x 1080. This phone could be a good pick for fashion-conscious users with its unique materials. It’s also a great device for anyone after a compact form factor or who is a fan of Motorola devices. The style, compact design, external display, fast performance, and improved camera system (50MP) are all positives on this device. There’s also IP48 rating for dust and water protection, adding durability. Motorola Razr Ultra 2025: $1,099.99 (Amazon US) / MSRP $1,299.99 This Amazon deal is US-specific and not available in other regions unless specified. If you don't like it or want to look at more options, check out the Amazon US deals page here. Get Prime (SNAP), Prime Video, Audible Plus or Kindle / Music Unlimited. Free for 30 days. As an Amazon Associate, we earn from qualifying purchases.
      Doreen768 earned a badge
      James_kobe earned a badge
      macomen earned a badge
      168
      125
