[C] "isdigit" validation problems
Hello! I have a small program which calculates tax. I've got all the requirements down except for one which is racking my brain. I tried using "isdigit" to validate the user input for the menu so entering a letter doesn't make it go nuts but I can't get it to work. I have a "while" loop validating the entry to make sure it's within the range of possible options (1-4), just need to weed out the letters. The code is posted below. Any help would be greatly appreciated!
*  Source File Name: Tax Calculator.c				  *
*  Date Final Submmitted: 3/9/09				  *
*  Description: 						  *
*  This program takes values assigned to variables and calculates *
*  the tax and for each of the Kudler Fine Foods locales	  *
*  Initial program has all of the values hard coded.		  *
*  Date	Modified by   Description of Change			  *
*  022309  Change Request #1 to prompt the user for *
*		  the grocery amount, and calculate and display total	  *
*		  sales amount.					  *
*  030209  Change Request #2 to add menu selection  *
*		  for Location and display only the tax and total for	  *
*		  that location.					  *
*  Here are the INCLUDES that are needed						  *
#include <stdio.h>
#include <ctype.h>
*  Here are the Function Prototypes that are needed			   *
void getfAmount();
void printTableHeader();
void printLocMenu();
float calcSalesTax(float, float);
float calcTotal(float, float);
*  Float variables:			 						*
*  fAmount is the amount of the groceries		 		  *
*  fDelMarTax is the tax rate for DelMar					*
*  fEncinitasTax is the tax rate for Encinitas			  *
*  fLaJollaTax is the tax rate for La Jolla				*
float fAmount=0.00;
int iSelection=0;
int iValidate=0;
float fDelMarTax=7.25;
float fEncinitasTax=7.50;
float fLaJollaTax=7.75;
float fDelTaxTotal=0.00;
float fEncTaxTotal=0.00;
float fLaJTaxTotal=0.00;
main() //Start main function
   printf("\t\tKudler Fine Foods\n");
   printf("\t\tTax Calculator\n\n");
   //Location selection menu
   printf("\nLocation Menu\n");
   printf("\n1\tDel Mar");
   printf("\n2\tEncinitas");
   printf("\n3\tLa Jolla");
   printf("\n4\tQuit\n");
   printf("\n\nEnter your selection (1-4): ");
   scanf("%d", &iSelection);
//Need verification to weed out letters using isdigit if possible
	  while (iSelection < 1 || iSelection > 4) {
		 printf("\nPlease enter a valid number (1-4): ");
	  if (iSelection == 1) {
		 getfAmount();
		 fDelTaxTotal=calcSalesTax(fAmount, 7.25);
		 printTableHeader();
		 printf("\n\nDel Mar\t\t%.2f\t\t$%.2f\t\t%.2f\n", fDelMarTax, fDelTaxTotal, calcTotal(fAmount, fDelTaxTotal));
	  if (iSelection == 2) {
		 getfAmount();
		 fEncTaxTotal=calcSalesTax(fAmount, 7.5);
		 printTableHeader();
		 printf("\nEncinitas\t%.2f\t\t$%.2f\t\t%.2f\n", fEncinitasTax, fEncTaxTotal, calcTotal(fAmount, fEncTaxTotal));
	  if (iSelection == 3) {
		 getfAmount();
		 fLaJTaxTotal=calcSalesTax(fAmount, 7.75);
		 printTableHeader();
		 printf("\nLa Jolla\t%.2f\t\t$%.2f\t\t%.2f\n", fLaJollaTax, fLaJTaxTotal, calcTotal(fAmount, fLaJTaxTotal));
	  if (iSelection == 4) {
		 printf("\n\n\tThank You.");
} //End main function
*  Here are the Function Definitions that are needed			  *
void getfAmount()
   printf("\n\nEnter the purchase amount: $");
   scanf("%f", &fAmount);
   //While loop for positive number verification
   while ( fAmount <= 0 ) {
	  printf("\nInvalid purchase amount.");
	  printf("\nPlease enter a valid purchase amount: $");
   } //End while loop
} //End function definition
   printf("\n\n\nLocation\tSales Tax\tTax Amount\tTotal Price\n");
float calcSalesTax(float fAmount, float locTax)
   return (fAmount*locTax)/100;
float calcTotal(float fAmount, float locTotalTax)
   return (fAmount+locTotalTax);
https://www.neowin.net/forum/topic/742542-c-isdigit-validation-problems/
you can try using atoi
http://www.cplusplus.com/reference/clibrar...tdlib/atoi.html
because i bet your code fails where if its a string!
On success, the function returns the converted integral number as an int value.
If no valid conversion could be performed, a zero value is returned.
If the correct value is out of the range of representable values, INT_MAX or INT_MIN is returned.
so you'll do something like
int menu = atoi(*menu_number)
if(menu)//if(0) is false
if(menu == 1)
... etc
  bookieass said:
you can confine your condition by converting the input into ascii values and checking whether it lies withing the given specified range of numbers
Hope it wll help :)
Sounds like it would work. How do I go about doing that? This is for my class so I'm just now learning about it all. :D
I dont know much of C++
Please rectify
#include <iostream.h>
#include <stdlib.h>
int main()
		int number;
		char letter;
		int option;
		cout<<"Convert ASCII numbers into characters and vice versa";
		cout<<endl<<"[1] * ASCII -> ABC"
				<<endl<<"[2] * ABC -> ASCII"
				<<endl<<"[3] * EXIT"<<endl;;
		cin>>option;
		switch (option) //Detects the option
				case 1:
						cout<<"Enter a number : ";#
						cin >> number; //Inputs the number#
						cout<<"The number you entered is : \""<<char(number)<<"\" in ASCII"<<endl; //Ouputs the same number in char
						break;
				case 2:
						cout<<"Enter a letter : ";
						cin >> letter; //Inputs the letter
						cout<<"The character you entered is : \""<<int(letter)<<"\" in ASCII"<<endl; //Outputs the same letter in int
						break;
				case 3:
						return 0;
				default: //If user chooses anything else besides options given
						cout<<"Invalid Option!";
						system("PAUSE");
						break;
		system("PAUSE");
		return 0;
You can do that using following code
for more about ascii table and their corresponding values refer this
U can see from there that numeric numbers [single character] will definately have values 48-57
Hope it would help a little :)
You can also do it using cin.ignore(), I can't post the link right now because I'm at Uni but I'll post it later. I was using something identical to this because I only wanted an integer within a specific range from the user, and reject everything else.
edit: if you look on Google, you're looking for input validation
Can't edit my post now. The bookmark I had saved isn't loading so here's the code I use to get my user data
int GetUserData()
	bool invalid = true;
	while(invalid == true)
		cin >> input;
		if (cin.fail()){
			cin.clear();
			cin.ignore(400, '\n');	// clear the stream
			continue; // try again
		// If more than two characters were cleared from the stream
		// input is invalid
		if (cin.gcount() > 1){
			continue;
		// Integer has been provided, now check its range
		if ( << RANGE CHECK YOUR INTEGER HERE >>){
			continue;
		}else{
			// integer is valid
			// Do stuff here
			invalid = false;
	return input;
I think its pretty bullet proof for checking you have an integer and it's in the range you're looking for. Hope it helps!
Whoops my bad!! :blush: I'll have a look for something in C!
edit:
How about this? I tested it for character input and sets of characters and it worked fine.
#include <stdio.h>
int main(void)
	int number;
	char ch;
	printf("Enter a number between 1-4\n");
	do {
		fflush(stdin);
		printf("Choice: ");
		ch = getchar();
	} while(ch!='1' && ch!='2' && ch!='3' && ch!='4');
	printf("\n");
	number = ch - 48;   // convert ascii number code to its decimal equivalent
	printf("You entered number %d\n", number);
	return 0;
The number 48 is used to convert the ASCII code for 1-4 to its decimal equivalent and fflush is used to clear stdin of any excess characters. Hope this helps :)
Edited by ViZioN
No problem! :woot:
I've tried "isdigit" a few times but it never works. It either always comes out "false" or doesn't work at all. All I want is for user input of letters to no break the program when a user is asked to pick between 1-4. :D
It worked! Thank you!! :D
Just some small editing for it to fit with my code and it did the job.
Edit: Just noticed I can remove the part to check for less than 1 or greater than 4. :)
	  do {
		 fflush(stdin);
		 ch = getchar();
	  printf("\n");
	  iSelection = ch - 48;   // convert ascii number code to its decimal equivalent
etc...
Wow that's weird. I just tried it and you're right, I wonder why that is. :p
I noticed another problem. In my original code posted up top you'll see that I have the user input a price and that's done through a function. However, if you input a letter it breaks it as well. The difference is that it's not a defined range of numbers as the menu but any positive float number. Can the method you gave me for the menu be adapted to work for float numbers so that letters don't break that portion of the code?
I used to hate programming and now this simple program has spiked my curiosity. It's only beginners code! :p
Well if you think what is happening, getchar() is taking a single character from the input stream which could be 3 or 3999993 but it only takes one character. The rest is then cleared by using fflush(). Hence when the character is checked it is valid.
I'm not sure if it could be adapted to work for floating point numbers. I'll have a think and a look around :p
edit: I found this which is a function for converting an ascii string to a floating point number. Don't worry about it saying C++, it is actually C code. The good thing is that, if no valid conversion can be perfomed it returns 0 so you can simply loop till the user provides a float that is valid :)
Something like this?
#include <stdio.h>
#include <stdlib.h>
int main ()
	double n;
	char szInput [256];
	do{
		printf ( "Enter number:");
		gets ( szInput );
		n = atof ( szInput );
	}while(n == 0);
	printf ( "Value: %f" , n );
	system("PAUSE");
	return 0;
Edited by ViZioN
no point in dealing with floats, ATOI (3rd post) works just fine
If he's wanting to enter floating point numbers why use atoi? It will truncate the float which is pointless as the whole reason you are using a float is for the extra precision.
I have to use floats with money! :p
Edit: Ok, I modified it for my code but it prints the "Enter the purchase amount: $" statement twice, not sure why. Aside from that it works as it should!
void getfAmount()
   do {
	  gets(szInput);
	  n=atof(szInput);
   } while(n == 0);
Edited by Crackler
void getfAmount()
   do {
	  gets(szInput);
	  n=atof(szInput);
   } while(n == 0);
whoops i guess the problem changed over the past few posts
i thought it was regarding the MENU selection.
sorry lol
  Crackler said:
I found another bug! It allows the user to enter negative numbers which doesn't exist for money. :p
Fixed the negative number problem. Using your function code, I don't get the purchase amount statement twice. Can you confirm if you still get it? Easiest solution for the negative number is to change the while condition from == 0 to <= 0
#include &lt;stdio.h&gt;
#include &lt;stdlib.h&gt;
void getfAmount();
int main ()
	getfAmount();
	system("PAUSE");
	return 0;
void getfAmount()
   double n;
   char szInput [256];
   do {
	  gets(szInput);
	  n=atof(szInput);
   } while(n &lt;= 0);
  Crackler said:
This simple program is getting worse by the minute, I can just imagine "real" programs. :D
Input validation is actually a fairly large coding problem. It's quite difficult to make your code bullet proof, and to stop any user from causing buffer overruns etc
I'll post all of the code since I still get the statement twice. The other problem is within the calculations. Wherever "fAmount" is now I have to replace it with either "n" or "szInput" to properly calculate the tax and total, but neither work. :wacko:
BTW. thanks for all the help!!
*  Description: 						  *
*		  sales amount.					  *
*		  that location.					  *
#include &lt;ctype.h&gt;
void getfAmount();
*  Three float variable for calculated tax amounts	   	  *
float fAmount=0.00;
int iSelection=0;
char ch;
double n;
char szInput [256];
	  do {
		 fflush(stdin);
		 ch = getchar();
	  } while(ch!='1' &amp;&amp; ch!='2' &amp;&amp; ch!='3' &amp;&amp; ch!='4');
	  iSelection = ch - 48;   //Convert ascii number code to its decimal equivalent
		 getfAmount();
		 printTableHeader();
		 getfAmount();
		 printTableHeader();
		 getfAmount();
		 printTableHeader();
void getfAmount()
   do {
	  gets(szInput);
	  n=atof(szInput);
   } while(n &lt;= 0);
   /*printf("\n\nEnter the purchase amount: $");
   scanf("%f", &amp;fAmount);
   while ( fAmount &lt;= 0 ) {
   } //End while loop*/
Think it's all working now ;)
Didn't really change much. For some reason you had nothing before your main() so I made it an int. Didn't want to compile for me otherwise. Fixed the double message to. It was due to where I had the fflush(stdin). I moved it after the getchar() and the double statement stopped occuring. Not entirely sure why. Then I fixed why your tax wasn't working. Your getfAmount() function is void, i.e it doesn't return anything, so whatever input you get from the user, is never returned from the function. And I moved n and szInput into your getfAmount() into the function so they're now local variables to the function. There's no need for them to be global.
It's now:
float getfAmount()
so it returns the user entered data.
Finally I set this value to your float fAmount variable so you can use it elsewhere in the program.
Full code:
*  Description:						   *
*		  sales amount.					  *
*		  that location.					  *
float getfAmount();
float fAmount=0.00;
int iSelection=0;
char ch;
int main() //Start main function
	  do {
			ch = getchar();
			fflush(stdin);
		 fAmount = getfAmount();
		 printTableHeader();
		 printTableHeader();
		 printTableHeader();
	system("PAUSE");
	return 0;
float getfAmount()
	double n;
	char szInput [256];
	do {
		gets(szInput);
		n=atof(szInput);
   } while(n &lt;= 0);
	return n;
  Crackler said:
I think it's the compiler that's different. It compiles just fine for me as I posted it without the int before main, etc. I hand edited my code to incorporate the fixes you came up with and it works perfectly. :D
Thanks a million!!!!
Well thanks to vizion!!! he made up
was sleeping (bcoz of time line difference) whn u were busy coding :)
    • At least on Mint... Debian is the 'backup' option (i.e. LMDE6) where as regular Mint is Ubuntu. also, Debian tends to play stuff a bit more conservatively than Ubuntu (at least based on Mint) with kernel and programs. also, even Mint's 'Update Manager' is more refined in regular Mint vs LMDE6 and installing NVIDIA driver is easier on regular Mint etc. not only that but LMDE6 only comes with Cinnamon which is a shame as they should offer the option for Xfce. I realize playing around with it in a VM one can install Xfce on it but it would be nice to have a more official Xfce release like how the regular Mint does. so while I heard Debian is a little snappier than Ubuntu (so better on some level), Ubuntu is probably the overall wiser choice unless people don't mind using a bit older stuff etc. but honestly, with some tweaks I would not mind if they changed the main Mint to Debian base instead of Ubuntu. but that's probably not likely to happen unless Ubuntu really does something the Mint team does not like. p.s. but I was building Super Mario 64 (native PC port on Linux) a while ago and it does not like regular Mint but works fine on LMDE6. but at that point I just transferred the final binary out of the VM back to my regular Mint and it works fine.
    • Excel is getting a highly requested PivotTable feature by Usama Jawad Microsoft Excel is one of the most popular software out there, both in the enterprise and personal space. It has a variety of use-cases including data analysis, data crunching, visualizations, and even planning and organization assistance. Microsoft regularly updates Excel with new features, and now, it is introducing a notable feature for PivotTables. Prior to today, PivotTables required a manual refresh from the user whenever new data was inserted into them. This wasn't a particularly complicated process, but it was tedious, so based on significant user feedback, Microsoft has decided to implement auto-refresh capabilities in PivotTables. The good thing is that Auto Refresh is enabled for all new PivotTables by default, but you can choose to disable it by selecting a PivotTable, navigating to the PivotTable Analyze tab, and then clicking on Auto Refresh. It is important to note that Auto Refresh is applicable on a per data source level, which means that the feature's state (on or off) will apply to all PivotTables derived from that source. Additionally, if Auto Refresh is disabled or a PivotTable is unable to synchronize, a message at the bottom of your workbook will say "PivotTable Refresh Needed". Once you click on it, all outdated PivotTables will refresh. Finally, you should keep in mind that external and asynchronous data sources do not support Auto Refresh and that the feature may become unavailable when a co-author is using an older version of Excel or if you are playing around with volatile functions like RAND() and NOW() in your data source. Auto Refresh for PivotTables is available right now in the Beta Channel for Excel for Windows version 2506 (Build 19008.2000) or later, and Excel for Mac version 16.99 (Build 250616106) or later. If you don't see it yet, it's better to wait as new capabilities are often rolled out in a staggered manner.
    • Hell of a legacy, hell of a bad person...
    • Man, what a legend. I know a lot of you don't like social media but the outpouring on the platforms has been really something else.
    • No download links, please.
      Electronic Person earned a badge
      CyberCeps666 earned a badge
    • Very Popular
      d4l3d earned a badge
      Very Popular
      Stephen Leibowitz earned a badge
      Snake Doc earned a badge
      163
      124
