Ok I have a Linksys Router (NOT WIRELESS) and share xbox and 3 pc's on it I want to put 2 pcs in diff rooms and wanted to know would I need to buy a wireless router or!!! could I buy two of these
Blitzz Netwave Point Point USB 802.11b 11Mbps Wireless LAN USB Adaptor, Model# BWU603
Specifications:
Data Rate: 11, 5.5, 2, 1Mbps auto adaptive
Coverage Area: Indoor (50M @ 11Mbps) Outdoor (150M @ 11Mbps)
Roaming: 802.11 compliant
Security: 64-bit and 128-bit WEP Encryption
Wireless Interface:
Port: Wireless antenna
Interface: IEEE 802.11b
Antenna: 2 Omni antenna
Frequency: 2.412~2.462 GHz
Operating Channels: 11 channels
Network Interface:
Interface: USB 1.1
Connector: Mini type USB connector
Put one in my comp. to get net and put the other one in another comp and get net from the one I have on my computer will that work?
Please HELP!
https://www.neowin.net/forum/topic/74530-wireless-networking/
Sorry to mention a mac here, but I know in OS X you can network two computers via just access points by enabling internet sharing and selecting the internet source and access point for broadcasting so im pretty sure you should be able to in Windows XP, don't know about anything below it though. If it's not built-in to the OS there should be a freeware or cheap app that would allow you to configure it this way. I'd say just get the two from a place that allows returns and if they don't work, send em back. Just remember, you'll have to keep the main PC on all the time otherwise the other two won't have net access.
yea i think if i you use ics you can bridge together to wireless cards together but u said u want to computer u might run into a problem.
*only is you go the ICS route*Since u said u had a linksys router make sure you go in and chaneg the default lan ip to be 192.168.0.1 and not 192.168.1.1
There is a SIMPLE RULE OF THUMB ABOUT WIRELESS
YOU NEED AT LEAST TWO WIRELESS TO DEVICES TO GET WIRELESS!!
If you have a router, w/o a wap and just a USB Wireless Adapter, you get poop OK.
You still Need the WAP for the router.
You to have something to send and recieve the wireless signal.
The Entire Wireless Router's are cheaper than just bying the add on Ethernet WAP.
Linksys BEFW11S4 version 2 or 3. will do the job.
When building my Wireless network I have found out two things. One of which is about Blitzz.
Blittz makes a great Mobile card, but their other equipment with the PCI Wireless card being especially noted; because it looses signal often, even if it's within close open proximity of the wireless router.
I would use a different brand, namely Linksys or Netgear. These two brands are excellent quality at reasonable prices. If you were to pay 10 - 20 bucks more (on average) to get the above mentioned, it would be worth it to you for 3 reasons.
1. Quality + Wi-Fi certified + Docs
2. WEP Encryption can Generate HEX (this comes in really handy)
3. Software is better and updated more frequently with support to boot
If you have a wired hub and want to share with a wireless device, you have a couple of options.
Get a Wireless Router and a Wireless Device (USB, PCI, Mobile; they are usally within the same price range)
Get a Wireless Device and another Wireless Device
Probably the easiest to setup and deploy are the USB Wireless, if you choose this option, go with the linksys because they seem to be more up-to-date on the firmware and drivers than Netgear is (only marginally so)
You would run these two devices on Ad-Hoc to have them talk to each other, and then everything else included with getting the internet piped through the wireless is post mortem :happy:
If you have Windows XP bridging the two devices it won't work the way you want it to, so you would use the ICS, which is available on all versions of windows since 98 SE. Since ICS throws an IP to a connecting device that listens for DHCP, it will seamless connect to a Mac regardless, if you are using a windows machine as a gateway.
Edit: The only other thing I can think of regarding this, is, that sometime you would need to manually enter in the gateway IP for it to acquire the DHCP information.
If you are using a Mac as a Gateway, I'm sure there is a similiar configuration for Internet sharing, I'm 80% sure Mac OS.X will have this. Both should be easy to setup.
you can watch your local best buy or circuit city, open box buys come with the same warranty as a new part, only difference is, it left the store for some reason. both my router and my sony video cam i got open box buy, i saved 100+ on the router and 400 on the camera. depending on if its best buy or cicuit city, you can save more than listed...for instance, CC wanted 1200 for a new camera, there was an open box for 1050, the sales girl told me shed give it to me for 1000, i said 750, she said 850, i said 800 and stated that i could get a new one for that via the web...i got it for 800 and away i went, she gets her commission back on the returned item and i get a cheap camera. linksys and d-link are notorious for mail in rebates...just keep watching and you'll score one for at least 40% off.
