Need help with installing java and java plugin on ubuntu 8.10
hey e1 hope all is having a good day.i havent been back to ubuntu for a couple of months and i reinstalled this morning can someone help me get java installed and the plugin for firefox. looks like it has changed you cant install java6 anymore thru synaptics looks like its called icedtea6 i play on pogo.com and it uses java plugin if anyone could help me at all ty ty
Icedtea is the Open Source implementation, if I recall correctly.
I have had better success with Sun's Java.
Once you browse to a site that uses Java, you should be prompted for a plugin. I believe it will present the options for you (IcedTea, Sun, whatever else). Click Sun and apply.
Should be all you need to do.
ok the apt-get install sun-java6-plugin doest work this is what i get
randall@ubuntu:~$ sudo apt-get install sun-java6-plugin
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package sun-java6-plugin is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package sun-java6-plugin has no installation candidate
randall@ubuntu:~$
ok i tried that and it wants me to download the file from java and install that way but doesnt work either
ok i tried the instructions mephistopheles and i get this error after i do this command
sudo apt-get install sun-java6-jre sun-java6-jdk sun-java6-plugin
randall@ubuntu:~$ sudo apt-get install sun-java6-jre sun-java6-jdk sun-java6-plugin
Did you make sure that the 'restricted' and the 'multiverse' repositories are added to your /etc/apt/sources.list (see the article I linked to for details)?
yes i did
when i do this java -version it looks like it shows 2 javas
randall@ubuntu:~$ java -version
java version "1.6.0_0"
IcedTea6 1.3.1 (6b12-0ubuntu6.1) Runtime Environment (build 1.6.0_0-b12)
OpenJDK 64-Bit Server VM (build 1.6.0_0-b12, mixed mode)
  xrandallx said:
yes i did
Remove the IcedTea plug-in, then install the sun-java6-plugin.
ok everything to do with java has been removed java -version no longer show anything i made sure the sources where updated with what that site said that you gave me, did apt-get update and it updated then i rean the command to install and i get this still
First, so an apt-get update. Then, use synaptic to find sun java packages and install them. Be sure you went to Options;repository and enabled multiverse, restricted and commercial, apparently, you didnt. Then, update the package list again. They are there, even on jaunty (9.04).
ok i would like to update this thread thanks all for the help guys but i feel like a blonde lol i found out that im using the 64bit version of 8.10 and i recently upgraded to jaunty 9.04 to test and play around so here is the site that i found out how to install java and flash for my computer i did lots of googling java and flash for amd64 so now every thing is working and no problem :D
