- 0
Remote Desktop Connection using MSTC/Terminal
Asked by
halluc1nati0n,
Recently Browsing 0 members
Posts
By d5aqoëp · Posted
I am low-key enjoying the new start menu of 25H2 build. Looks like the management team who shoved the Recommended Section down our throats up till now got fired in recent gommage at MS. Also loving the 6Ghz Hotspot feature. I only enabled these 2 features and I am happy. I keep an eye on MDL forums for 26200.xxxx updates once a week to stay up to date manually. I downloaded the latest build from https://uupdump.net selected Dev Channel tab and downloaded amd64 build. Let the script ripp. Then I used vivetool to enable the above 2 features • 25H2 New Start Menu ViVeTool.exe /enable /id:47205210,49221331,49381526,49402389,49820095,55495322,48433719 • Enable Wifi 6Ghz Hotspot ViVeTool.exe /enable /id:40466470,48433719 Reboot and enjoy. Almost all the above info was provided by Neowin at some point. -
By +InsaneNutter · Posted
Indeed, I do think its sad in some ways a corporation can never be content with "performing well across every metric" and having over £59 billion cash on hand. -
By Gerowen · Posted
They've been focusing on security and quality? Could have fooled me. Their own paying customers literally just got breached because they failed to push SharePoint updates downstream to on prem servers operating outside of their "365" ecosystem. -
By Gerowen · Posted
The animosity is unnecessary, when I opened the page I only saw one response which never mentioned your other steps, and when I hit reply it jumped straight to the bottom and again, I saw no other responses. I was simply agreeing with the first comment that said yes, you should be fine if you erase its current operating system. Using another PC, or the copy of Windows that comes on that PC (former option is more trustworthy), download and run the Windows Media Creation tool. It will walk you thru the process of downloading Windows and writing it to a USB stick. It will even ask you at one point whether you're reinstalling it to the current machine or installing it on another machine. Then just boot the PC in question from that USB stick. Usually spamming Esc, Del, F-8, F-9, F-10, F-11, F-12 or F-2 immediately after power on will bring up a boot menu, it varies by manufacturer. If Windows starts booting you either missed your window or hit the wrong key. Follow the on-screen instructions. When it gets to the disk formatting part I usually just delete all the partitions on the destination drive, then select the unpartitioned space as my destination. The Windows installer will then automatically partition the drive as needed. Be prepared to download drivers from the PC manufacturer's website, they may not come bundled with Windows and you may not be able to use things like WiFi or ethernet until you have them. They "might" work straight away, but they also might not. Better to be prepared with a spare PC and a USB stick to transfer them over. -
Wise Disk Cleaner 11.2.5 by Razvan Serea Wise Disk Cleaner is a free disk utility designed to help you keep your disk clean by deleting any unnecessary files. Usually, these unnecessary, or junk files appear as a result of program's incomplete uninstalls, or Temporary Internet Files. It is best if these files are wiped out from time to time, since they may, at some point, use a considerable amount of space on your drives. Wise Disk Cleaner, with its intuitive and easy to use interface, helps you quickly wipe out all the junk files. Using the program is indeed easy. It also works fast when both scanning for files and deleting files. The new Wise Disk Cleaner has more advantages: improved performance, better interface and scans/cleans more thoroughly. Wise Disk Cleaner Free provides lifetime free update service and Unlimited Free technical support. The first Slimming System software Wise Disk Cleaner is the first system slimming tool, which will help you to remove Windows useless files that you don't need, such as Korean IME, Windows Sample music, videos, pictures, Installers and Uninstallers of Updates Patches etc. Wise Disk Cleaner 11.2.5 Build 845 changelog: Added cleaning rules for Legacy Games Launcher, Letasoft Sound Booster, Macrium Reflect, MagicLine4NX, MAGIX Photostory, MakeHuman, Max Recorder, Maxprog iCash, Lexware, LG PC Suite, Lightworks, LINE, Listary, and LockHunter. Improved cleaning rules for Xunlei, PowerToys, Meitu, OneDrive, and Tencent Video. For security reasons, users can no longer delete the latest system restore point in the Restore Center. Enhanced System Slimming. Fixed minor bugs from the previous version. Download: Wise Disk Cleaner 11.2.5 | 6.9 MB (Freeware) Download: Portable Wise Disk Cleaner 11.2.5 | 7.3 MB View: Wise Disk Cleaner Home Page | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
Recent Achievements
Philsl earned a badge
armandointerior640 earned a badge
Itbob513626 earned a badge
Popular Contributors
Tell a friend
halluc1nati0n
I'll need to connect to a desktop in a different city (remotely). Both systems which are gonna be used run Windows..
I do get the concept of VNC - but getting the VNC server to run in the other system is the real pain..
Can MSTSC (Microsoft Terminal Services) built into Windoze achieve this? Do I just need to get the other IP address? Is it that simple? Bear in mind I'll be using the internet to connect to the other remote PC ..
I could probably use TERMINALS over MSTSC as it does have other advantages..
So again, If I do connect over the net, is it just the IP address that I require? Do I need to know of any open port as well?
EDIT : Spelling mistake in title :( Should've been MSTSC for MSTC..
Edited by halluc1nati0nLink to comment
https://www.neowin.net/forum/topic/752944-remote-desktop-connection-using-mstcterminal/Share on other sites
9 answers to this question
