Wierd context menu problem
I am running windows server 2003. This is similar to that problem that your cpu usage goes to 100%. When I move my house over any menu with an arrow, drop down menu my pc freezes up really good and doesnt do anything. Even opening the start menu triggers this strange problem. PLease help.
https://www.neowin.net/forum/topic/75678-wierd-context-menu-problem/
I don't think i was clear enough as to what i meant. What i meant was: Any time i hover my mouse cursor over a pull-out menu Windows server 2003 goes to 100% cpu usage. Thus frezzing my computer good. If you let it be for a good 30 seconds it usually will recover itself. I have plenty of ram with 512MB... Here is a screenshot as to what kind of menu it will do this with.
LOL
Set the menushowdelay to 8
This will be fast still and also wont have any delays hopefully.
See how that goes.
Use this reg file also if you want to do it other then manually.
EDIT
Rememeber to log off and back on, or reboot for change to take effect.
ChangeMenuShowDelayTo8.zipFetching info...
Edited by Davey
  • 1 year later...
