Batch Script to delete, choose random, rename and move. PLEASE HELP!
5 answers to this question
Hi,
Something like the following should work, although I haven't tested it.
Dim firstPath : firstPath = "C:\Users\Matt\Desktop\TestFolder1\"
Dim secondPath : secondPath = "C:\Users\Matt\Desktop\TestFolder2\"
Dim fileSystemObject : Set fileSystemObject = CreateObject("Scripting.FileSystemObject")
Dim fileName : fileName = "x.jpg"
If (fileSystemObject.FileExists(firstPath & fileName)) Then
	fileSystemObject.DeleteFile firstPath & fileName
End If
Dim allFiles: Set allfiles = fileSystemObject.GetFolder(secondPath).Files
Dim imageFiles : Set imageFiles = CreateObject("Scripting.Dictionary")
Dim count : count = 1
Dim file
For Each file In allFiles
	If (Right(Lcase(file.Name), 4) = ".jpg") Then
		imageFiles.Add count, file.Name
		count = count + 1
	End If
Next
Randomize
Dim random : random = Int((count - 1 + 1) * Rnd + 1)
fileSystemObject.MoveFile secondPath & imageFiles(random), firstPath & fileName
The idea is we do the following:
  1. If the target image currently exists, delete it.
  2. Get a list of all the available files in the source directory.
  3. Create a list of all the available images in the source directory.
  4. Generate a random number used as the key in the dictionary of available images.
  5. Perform the rename of the source image as we move it to the target directory.
Make sure you test it first, as I haven't.
  Antaris said:
Hi,
End If
Dim file
		count = count + 1
	End If
Next
Randomize
Hi really appreciate but I need it in MSDOS command prompt. Windows batch file. Are you able to help as well?
Batch simply isn't advanced enough to do this. Random selection is the main problem, it has no method to find a random number. Complex things like this aren't for batch. Use vb.net, its simple and its the language the previous poster used. If needed you could use vb.net and choose 'Console Application' to run it in a command prompt window.
Wrong, you can do this. You would just have to know the names of the .jpg files in the Directory B, and how many.
@echo off
set 1=A .jpg file location in directory B. (C:\Directory B\)
set 2=A .jpg file location in directory B. (C:\Directory B\)
set 3=A .jpg file location in directory B. (C:\Directory B\)
set 4=A .jpg file location in directory B. (C:\Directory B\)
\\keep on doing this for how ever many .jpg files there are
set /a random2=%random%%%5
if %random2%==1 set random2=%1%
if %random2%==2 set random2=%2%
if %random2%==3 set random2=%3%
if %random2%==4 set random2=%4%
del C:\Directory A\X.jpg
move C:\Directory B\X.jpg C:\Directory A\
echo A new, random .jpg file has replaced the old .jpg in Directory A.
pause
On line number 7, you have to change the "5" to 1 more than the currrent number of .jpg files Directory B. This is so that it selects a number 1-n.
Edited by PVVnT(0)L
Hi I really need help with creating a batch file that does the following. pleas help!
1) Delete "X.jpg" from directory A,
2) Choose random .jpg file in directory B and rename it to "X.jpg",
3) Move "X.jpg" from Directory b to directory A.
Please help
junjie: Did you mean copy instead of rename ? (This technique is used to show random images on a web page.)
Good responses so far. Here is an alternate script that would work on Windows. This is not absolutely random but comes clsoe. (Please test it first.)
var str list; lf -n "*.jpg" "DirectoryB"  # DirectoryB is the directory B.
var int count; set $count = { len $list }
var int s; set $s = makeint(str({chex "12[" gettime()}))
var int random; set $random = $count/60*($s+1)
# We want to copy random'th file to X.jpg.
var str file; set $file = { lex makestr(int($random)) $list }
system copy $file "DirectoryA/X.jpg" # DirectoryA is the directory A.
This script is in biterscripting ( http://www.biterscripting.com ). Email me if you need further help.
Sen
    • It's significant growth for Linux considering the market share, so it could have had that effect I described.
    • Microsoft and Crowdstrike announce partnership on threat actor naming by Pradeep Viswanathan Whenever a cyberattack is discovered, companies disclose it to the public and assign it a unique name based on their internal procedures. Unfortunately, this leads to inconsistencies, as each company has its own naming conventions. As a result, the same threat actor behind a cyberattack may end up with multiple names, causing delays and confusion in response efforts. For example, a threat actor that Microsoft refers to as Midnight Blizzard might be known as Cozy Bear, APT29, or UNC2452 by other security vendors. To address this issue, Microsoft and CrowdStrike are teaming up. These companies will align their individual threat actor taxonomies to help security professionals respond to cyberattacks with greater clarity and confidence. It’s important to note that Microsoft and CrowdStrike are not attempting to create a single naming standard. Instead, they are releasing a mapping that lists common threat actors tracked by both companies, matched according to their respective taxonomies. The mapping also includes corresponding aliases from each group’s naming system. You can view the joint threat actor mapping by Microsoft and CrowdStrike here. Although this threat actor taxonomy mapping is a joint effort between Microsoft and CrowdStrike, Google/Mandiant and Palo Alto Networks' Unit 42 are expected to contribute to this initiative in the future. Vasu Jakkal, Corporate Vice President of Microsoft Security, wrote the following about this collaboration with CrowdStrike: As more organizations join this initiative, the collective defense against cyber threats will undoubtedly be improved.
    • You make no sense since most of the stuff on YouTube is free to begin with. Comparing Netflix to YouTube is not even remotely the same. YouTube has tons of free videos to begin with, unlike Netflix, you are paying Netflix for original style of programming.
    • Youtube can go screw themselves. Never ever, ever will I pay for this BS nonsense. And I encourage anyone else not to either.
      chriskinney317 earned a badge
      Nullun earned a badge
      sultangris earned a badge
      ClarkB earned a badge
      snowy owl
      122
      116
