Cosmin Posted May 8, 2003 Share Posted May 8, 2003 I've setup an ICS for my both PC's . First machine : 192.168.01 ( as was mentioned ) Second machne : 192.168.02 ( manually ) Gateway shows that trafic is coming from the server to the client but the client cannot open any page ( does not open ) .. -The ICS was setup with the wizard ( all ok ) . -The server & client have the FIREWALL DISABLED Where should I also look / check ? Thank a lot , Cosmin ______________ Pics ______________ Link to comment https://www.neowin.net/forum/topic/77846-ics-internet-connection-sharing-with-problems/ Share on other sites More sharing options...
Cosmin Posted May 8, 2003 Author Share Posted May 8, 2003 and the taskbar .. Link to comment https://www.neowin.net/forum/topic/77846-ics-internet-connection-sharing-with-problems/#findComment-843257 Share on other sites More sharing options...
Steven Posted May 8, 2003 Share Posted May 8, 2003 DNS :) try going to websites via IP addy only. Link to comment https://www.neowin.net/forum/topic/77846-ics-internet-connection-sharing-with-problems/#findComment-843269 Share on other sites More sharing options...
NeoMayhem Posted May 8, 2003 Share Posted May 8, 2003 Make sure your DNS server is set to the ICS computers IP ;) Link to comment https://www.neowin.net/forum/topic/77846-ics-internet-connection-sharing-with-problems/#findComment-843286 Share on other sites More sharing options...
mwk3 Posted May 8, 2003 Share Posted May 8, 2003 also, try setting the dns on the second computer to 192.168.0.1 you should just make the second get an ip and dns automatically. you shouldn't have to set anything manually on the second computer Link to comment https://www.neowin.net/forum/topic/77846-ics-internet-connection-sharing-with-problems/#findComment-843288 Share on other sites More sharing options...
Cosmin Posted May 8, 2003 Author Share Posted May 8, 2003 mwk3 said: also, try setting the dns on the second computer to 192.168.0.1 you should just make the second get an ip and dns automatically. you shouldn't have to set anything manually on the second computer worked . thanks a lot guys :yes: :) Link to comment https://www.neowin.net/forum/topic/77846-ics-internet-connection-sharing-with-problems/#findComment-843419 Share on other sites More sharing options...
