- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
deep1234
Hi guys, I want to control a computer in my local wireless network using RealVNC. I installed VNC Viewer in my computer and VNC server in the remote compter.
For the remote computer I set the password and open the port for it in the firewall (port 5900 TCP), but when ever I try to connect to it from my PC it give me 'Connection closed unexpectedly'. I checked the FAQs of RealVNC and it refairs that the problem is related to firewall?!, but I opened the firewall in the remote PC? and I even open it in my PC but it is the same thing?
So guys what I can do more? I am not sure if this is right but do I need to open ports in the wireless ADSL? but I want this in the local network not accross the internet.
Please help and thank you in advance.
Note: forget to mention before that this happened, when I try to connect it give me a "connection aborted (10053)". but the weird thing that it can connect after I try to ping it from powershell, but it give me "Connection closed unexpectedly" later.
https://www.neowin.net/forum/topic/795614-problem-in-using-realvnc-in-local-wireless-network/Share on other sites
1 answer to this question
