Help! Command prompt opens (and stays open) at every program start (wh
Every time when i start a program (via the desktop or the program files) it starts first a command prompt with some startup information. When the prompt is closed, the gui is also ended.
I just cleaned the computer using this method and it is now malware free (99% sure about that)
I have run memtest86+ and the memory is fine.
The PC is a Dell Dimension 5150C
The HJT log shows nothing weird (This is not my first PC Repair and I am familiar with HJT)
Please comment, ? need help:))
This used to happen to me, right click on the icon, hit properties, and in the "Target" box make sure nothing is after the last ", sometimes if theres -image or -wmc after them (it used to auto do that to my shortcuts) it can run the command prompt; if not, i'm not sure.
Although your computer may be void of malware, this is most likely a residual effect of some piece of malware you removed. You could try an IPU, but I'm not sure that it will fix your problem. I agree with Ridlas that the best, and by far the quickest, solution is to simply reformat.
