Hi everyone,
this is quite urgent.
I have Windows 7 installed on this laptop and everytime this laptop is on, it will freeze/hang my two desktops.
Event ID: 8003
Source: Browser
Description: The master browser has received a server announcement from the computer <Windows NT client> that believes that it is the master browser for the domain on transport <NetBT>. The master browser is stopping or an election is being forced.
The best I can find to resolve the issue is from this link.
http://support.microsoft.com/default...b;en-us;135464
To stop the 8003 error messages, make sure the routers on the network are not forwarding UDP broadcasts, keeping browser elections on NetBT local to each subnet and enable WINS or lmhosts on the network for netbios name resolution.
Note Switches that are configured for VLAN's (virtual segmentation) have to be configured on a per VLAN basis to prevent UDP broadcast propagation.
Another resolution was:
To correct this problem, change the TCP/IP protocol configuration to the correct subnet mask.
http://support.microsoft.com/default.aspx?...kb;en-us;143153
However, I have no idea what that means or what to do on my router to resolve the issue.
I am running Tomato 1.25.
Please help me.
Thanks a lot.
edit: I THINK I solved it. What I did was for the client that was acting as a master browser, I went into Services > Computer Browser > selected Disable. The event 8003 has not occurred since for an hour, which is a good indication because normally it would appear every 30mins or so.
Edited by way2quik
https://www.neowin.net/forum/topic/841290-udp-subnet-mask-issue/
Um a master browser announcement would not freeze your machines??? These elections happen all the time.
But as above ^ if you do not want t machine to be a master browser disable the feature.. Or sure you could just disable the computer browser service ;)
Well best practice to make sure that machines that come on and off the network, like a laptop should not be part of the master browser election process, since sure when they boot up and not on the network or don't see a master browser they will assume they are it and then can force the elections.
Normally your machine that is on 24/7 should be set to be the only box to be the master browser so that you don't cause interruptions in the browsing service.. But to be honest its pretty much a useless feature anyway.. You normally should know the names of the servers or machines you want to connect to for shares - and no real need to browse for them just access with \\computername.
Not sure what was causing your freeze on your desktop machines - but I find it unlikely that browser election should cause the problem.
    • Mullvad Browser 14.5.4 by Razvan Serea The Mullvad Browser is a privacy-focused web browser developed in a collaboration between Mullvad VPN and the Tor Project. It’s designed to minimize tracking and fingerprinting. You could say it’s a Tor Browser to use without the Tor Network. Instead, you can use it with a trustworthy VPN. The idea is to provide one more alternative – beside the Tor Network – to browse the internet with more privacy. To get as many people as possible to fight the big data gathering of today. To free the internet from mass surveillance. The Mullvad browser is free of charge, open source, and can be used without Mullvad VPN (although the combination is recommended). It is supported across platforms (Windows, MacOS, Linux). Privacy quality of the Tor Browser. To use with a VPN - Using a VPN is not enough to achieve perfect privacy online. There’s simply too much data being extracted through most browsers. The Mullvad Browser is a web browser with the privacy quality of the Tor Browser, to be used with a trustworthy VPN. Strong anti-fingerprinting from the Tor Project - The Tor Project has a proven track record of building a privacy-focused browser. The Mullvad Browser has the same fingerprinting protection as the Tor Browser – it just connects to the internet with (or without) a VPN instead of the Tor Network. No telemetry - Telemetry refers to unique data collected by the browser to enhance its performance. Mullvad does not support the collection of user data. Therefore, with the Mullvad Browser, all telemetry has been removed. Privacy first - Mullvad VPN has a proven record of putting privacy first. With no strange business models or short-term venture capitalist owners. The Tor Project is a non-profit organization fighting for human rights. Mullvad Browser 14.5.4 changelog: All Platforms Updated Firefox to 128.12.0esr Updated NoScript to 13.0.8 Bug 450: Rebase Mullvad Browser stable onto 128.12.0esr [mullvad-browser] Bug 43782: Add new UX flow for changing security level (Desktop) [tor-browser] Bug 43783: Tighten up the SecurityLevel module to enforce new UX flow [tor-browser] Bug 43784: Get confirmation from NoScript that settings are applied [tor-browser] Bug 43911: Backport security fixes from Firefox 140 [tor-browser] Build System / All Platforms Bug 41477: Update keyring/boklm.gpg for new subkeys (2025) [tor-browser-build] Bug 41498: Update keyring/morgan.gpg with updated public key [tor-browser-build] Download: Mullvad Browser 14.5 | 90.6 MB (Open Source) View: Mullvad Browser Homepage | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • "To address the immediate privacy alarms this sets off, Meta says that its "Private Processing technology" will be used. This supposedly ensures that neither Meta nor WhatsApp can see your original messages or the private summaries the AI generates." Meta also says "Your privacy and safety are of utmost importance to us." This is also a lie. You know how you can make social media easier to manage? Get a life, and you'll no longer need it.
      solidox earned a badge
      blissa jayden earned a badge
      173
      Som
      151
