Random CPU Spikes in System process
For the last few days, I have been having random CPU spikes. The "System" process, about once every 1.5 to 2 minutes, takes up one entire core for about 10 seconds. Because it is the System process, I am suspecting it to be a driver (the most recent driver upgrades were installing Nvidia 195.62 laptop drivers (WHQL) and Realtek R239 HD Audio drivers, but I cannot lay the blame on an upgrade as I didn't notice exactly when the spiking started). I have ruled out other possible factors including malware and rootkits.
Process Explorer narrows it down to a thread that starts at Ntkrnlpa.exe!KeInsertQueueDpc+0x275, but because the System process is a protected process, it can't access any more information, including the thread stack. There are several other threads that start at the same address but do not spike.
How can I get more information about exactly what is causing the spikes or what function starts at KeInsertQueueDpc+0x275 or what execution stack it followed to cause the spikes? Any help in getting to the root of the problem is greatly appreciated.
https://www.neowin.net/forum/topic/859048-random-cpu-spikes-in-system-process/
Thanks for your suggestion. I have already used kernRates (using the symbols with Process Explorer wasn't helpful, as all it showed was that it was a thread from the threadpool, it couldn't show anything else as the System process is protected in Win7).
I have two installations of Win7 on the same system (one Pro, the other Ultimate). The spiking occurs only in Pro. I ran the same workload (same running processes plus uTorrent and FDM with same config downloading the same file) in both environments for one hour, with kernrates running. Comparing the results showed that Ntfs.sys generated about 10% of the events in Pro, whereas it was ~0% in Ult. I have no idea whats triggering this behavior in Ntfs.sys in Pro. Re-running the profiler without the downloaders running also gives the same result. The other modules have caused more or less similar percentage of events.
There isn't any disc thrashing occurring when there are CPU spikes (if it is of interest, regular filesystem tasks barely results in any CPU usage). So, it looks like the NTFS driver is repeatedly trying to do something but getting stuck in a loop without doing anything noticeable.
Will try profiling again with xperf and let you know the results.
But saw something else. Coinciding with the CPU spikes, interrupts also go up and file activity occurs.
In the graph, the green line is the CPU usage for interrupts, the red one for the CPU utilization of first core and blue for the CPU utilization of the second core. And the bars indicate file activity. At the CPU spikes, all events are occurring.
Looking into the CPU usage around the time of the spikes, sure enough the System process is spiking and except the kernel, the Ntfs.sys driver shows the most usage. The values are similar to the one traced by kernrates.
Looking into the details of file activity, there are three events the System process participated in. The huge towers for the file IO events occurred for the Create event.
The total time the System process spent for Creating files is close to five seconds, which is about the same duration the CPU spikes last, and generated about 250,000 IO Request Packets, which explains the spikes in file IO.
Each of those 260,000 events are created by Thread with Id 48 of the System process, which is confirmed to the same thread that spikes by using Process Explorer to look into the threads' activity of the System process during the spike.
Each of those events look same:
File Name: \Device\HarddiskVolume2\Windows\System32\drivers\etc\lmhosts
Flags: synchronous_io_nonalert Option24 normal shareRead shareWrite
Result: Object Name not found. (0xc0000034)
So it looks like its trying to create (or read?) the lmhosts file and failing. Sure the file isn't present in %windir%\System32\drivers\etc\; I do not use WINS. But why the hell is it trying to do the same for more than 250,000 times, when it has already failed once? And why is it doing this over and over again? I will try and create a dummy lmhosts file and see what happens, but that looks like a band-aid, not a solution.
Deleting and re-creating lmhosts fixed the problem, but it resurfaced on next restart. Dammit, I want a resolution. Don't ****ing care what the problem is anymore. I am taking a heavy hammer and disabling NetBIOS over TCP with brute force. No more NetBIOS, no more LanMan name resolution!
Ok, because you now know the cause, contact the MS support and tell them what you found out.
you can code a small program which creates the empty file. Now run the program with task scheduler at every startup. So you have a workaround until MS fixed it.
If anyone reading this topic has the same problem (I did), I've found a solution which appears to fix the problem for good
Open the properties box for a network adapter, any will do
Click TCP/IPv4 and then Properties
Jump to the WINS tab
De-select "Enable LMHOSTS lookup"
When you OK out of it the setting is applied to all network adapters
Hope this helps someone, spent most of my afternoon trying to find out what was going on
  • 2 years later...
It works! Thanks.
    • People yearn for the good old days of IRC and truly open Internet, yet are dismissive of modern solutions like ActivityPub (which Mastodon pioneered) and Matrix. Make it make sense.
    • AI judges learn new tricks to fact-check and code better by Paul Hill Image via Pixabay AI researchers and developers are increasingly turning to large language models (LLMs) to evaluate the responses of other LLMs in a process known as “LLM-as-a-judge”. Unfortunately, the quality of these evaluations degrades on complex tasks like long-form factual checking, advanced coding, and math problems. Now, a new research paper published by researchers from the University of Cambridge and Apple outlines a new system that augments AI judges with external validation tools to improve their judgment quality. This system aims to overcome limitations found in both human and AI annotation. Humans face challenges and biases due to time limits, fatigue, and being influenced by writing style over factual accuracy while AI struggles with the aforementioned complex tasks. The Evaluation Agent that the researchers created is agentic so it can assess the response to determine if external tools are needed and utilizes the correct tools. For each evaluation, three main steps are passed through: initial domain assessment, tool usage, and a final decision. The fact-checking tool uses web search to verify atomic facts within a response; code execution leverages OpenAI’s code interpreter to run and verify code correctness; and math checker is a specialized version of the code execution tool for validating mathematical and arithmetic operations. If none of the tools are found to be useful for making judgments, the baseline LLM annotator is used to avoid unnecessary processing and potential performance regression on simple tasks. The system delivered notable improvements in long-form factual checking, with significant increases in agreement with ground-truth annotations across various baselines. In coding tasks, the agent-based approach significantly improved performance across all baselines. For challenging math tasks, the agents improved performance over some baselines, but not all, and overall agreement remained relatively low at around 56%. Notably, the researchers found that in long-form factual responses, the agent’s agreement with ground-truth was higher than that of human annotators. This framework is extensible, so in the future, other tools could be integrated to further improve LLM evaluation systems. The code for the framework will be made open source on Apple’s GitHub, but it isn’t up yet.
    • https://www.neowin.net/news/tags/mastodon/ In short: Federated Twitter (X)
    • Keep in mind it was purchased by an advertising company. I use SearxNG.
    • I am using Waterfox Private Search now that I started using the Waterfox browser on my PC and Android. Both work great* search waterfox net with full stops in between. * I have an issue where making comments on articles on various websites is difficult with Waterfox on Android as it randomly adds spaces and doubles up on text.
    • Collaborator
      fernan99 earned a badge
      Collaborator
    • Collaborator
      MikeK13 earned a badge
      Collaborator
      Alexander 001 earned a badge
      Antonio Barboza earned a badge
      136
      126
