- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
semifamous
I need for users to be able to install fonts to their system without admin privileges at work. We have a system set up that installs software from a defined database that runs as SYSTEM, and that is working well so far.
I had thought that copying font files to the WINDOWS\Fonts directory would be enough to install them, but apparently it is not.
So I found a VB script that copies .ttf files to the Fonts directory using the Windows shell, causing the font to be properly registered. This runs at system startup as SYSTEM, so it has write permission to the directory. All they have to do is copy their new fonts to a directory on the file server and restart their system.
The problem is that this only copies files to the local system if they do not already exist there. I had been using robocopy to copy them over, but that wasn't registering them.
So now what I need to do is to figure out how to copy over fonts that are not correctly registered in HKLM\Software\Microsoft\Windows NT\Fonts
Alternatively, I need to be able to automatically delete .ttf files from the local system that are not correctly registered in that same registry key. I definitely don't want to go through the 1,500+ fonts manually.
I also need to be able to copy over .ttf, .otf, .fon and any other font extensions that are possible.
I don't know anything about VB script. Can someone explain how to make that go or write up something that would do that?
https://www.neowin.net/forum/topic/876530-vb-help-copyinginstalling-fonts-via-command-line/Share on other sites
6 answers to this question
