Hanging computer monitor, need help!
First off make sure it can be mounted. Check the manual. usually you can remove the stand and that is where you would screw in the mount.
I have gotten a few wall mounts from Mounts & More. Decent prices.
I just put a 27# LCD in my Bedroom with the this one. Linky! Works great.
