[C#, ASP.net] Help Designing Something
Alright, let me start with the fact that I do not consider myself a true .net coder by any stretch of the imagination, but it's gotten into My boss's head that since I can code some basic database interface tools I should be more then capable to coding something significantly more complex then this.
I've got a weird issue, where I don't even know where to begin to deal with:
Database design:
Categories:
ID, Name
Data:
ID, Name
AdjCategories:
ID, CatID, DataID
ValuePairs -
ID, CatID, DataID, Property, Value
so....
basically
we have a category: Colors
we have a Data: Blue
we have an adjustment: Blue in Colors
we have a value pair: (Blue in Colors) Has a a Property: HexCode and a Value: #0000FF
The data structure's pretty set in stone, I've stripped out a lot of extra data to keep this simple as possible... because it's already one of the longest posts i've ever made on this forum ;) and I haven't gotten to the issue.
the way we want to display the info :
Colors:
	Blue
		Key	|	Value
		Hex	|	#0000FF
		Plant	|	BlueBerries
		form for new entry to datapairs
	Red
		Key	|	Value
		Hex	|	#FF0000
		Plant	|	Apple
Where the form is allows the user to enter data into the Key/Value data.
Now I've nested a DataGrid inside a ListView to get the first two bits of the data displaying...more or less right... but how would I even handle the form? I am having a hard time figuring this out... and could use some help.
 <asp:ListView ID="ListView1" runat="server">
<LayoutTemplate>
                <span id="itemPlaceholder" runat="server"></span>
            </LayoutTemplate>
            <ItemTemplate>
                <span runat="server">
                    <asp:Label ID="Data" runat="server" Text='<%# Eval("strWord") %>' /><br />
                    <asp:DataGrid runat="server" AutoGenerateColumns="false" DataSource='<%# ValuePairDataProvider_DataSource() %>'>
                        <Columns>
                            <asp:BoundColumn DataField="id" Visible='false'></asp:BoundColumn>
                            <asp:BoundColumn HeaderText="Property" DataField="property"></asp:BoundColumn>
                            <asp:BoundColumn HeaderText="Value" DataField="value"></asp:BoundColumn>
                        </Columns>
                        <AlternatingItemStyle  BackColor="#eeeeee" />
                    </asp:DataGrid>
                    FORM GOES HERE
                </span>
            </ItemTemplate>
</listview>
https://www.neowin.net/forum/topic/882866-c-aspnet-help-designing-something/
0 answers to this question
There have been no answers to this question yet
    • And they didn't use Clippy for that? What a waste
    • Become a PDF Expert on your Mac — One-time purchase now at 42% off by Steven Parker Today's highlighted deal comes via our Apps + Software section of the Neowin Deals store, where for only a limited time you can save 42% on PDF Expert One-Time Purchase. PDFs remain the best way to transmit documents, but editing them isn't possible with standard Mac software. PDF Expert changes that, allowing you to edit PDF text, images, links, and outlines quickly and easily. Typo in a contract? Easy fix. Need to rework a complete section of a document? No problem. PDF Expert provides a series of essential functions that will transform the way you work with documents on your Mac. It recognizes text and OCR, makes edits, and fills out forms. And with the “Enhance” feature powered by AI, it will fix distortions, remove shadows and improve contrast so that even difficult-to-read documents look great. EDIT Change the text. Easily fix typos, update numbers, or add entire paragraphs Insert images. Update logos in a contract or add a new graph to a report Add links. Enrich your PDFs by linking to other pages or external websites ANNOTATE Highlight the important. Make the most valuable content stand out at a glance Comment on PDFs. Add text to PDFs, insert pop-up notes & write your thoughts in the margins Add stamps. Review documents with our set of stamps or create custom stamps for any workflow ORGANIZE Merge PDFs. Combine multiple files into one PDF document Manage pages. Add, delete, rearrange, or rotate PDF pages with ease Split PDFs. Extract pages from PDFs & save them as separate files CONVERT Convert to PDF. Turn JPG, PNG, Word, PPT, and Excel to PDF PDF to Word. Convert PDFs into editable Word documents PDF to image. Turn PDFs into JPG or PNG images PDF to Excel. Convert PDFs into Excel spreadsheets PDF to PPT. Save PDFs as PowerPoint presentations PDF to text. Convert PDFs into editable TXT files FILL OUT Fill out PDF forms. Easily fill out PDF forms by just clicking on them Sign documents. Add your signature to a PDF in a few clicks. Let customers sign documents with handy one-time signatures Redact PDFs. Blackout or erase confidential information from your documents RECOGNIZE TEXT OCR text in PDF. Recognize the text, so you can search, highlight & copy it Enhance scans. Fix distortions, remove shadows & improve contrast Crop & split pages. Split double-page scans into separate pages & remove undesired margins Good to know: Length of access: Lifetime Redemption deadline: redeem your code within 30 days of purchase Access options: Mac Max number of device(s): Unlimited usage on personal macOS devices Version: PDF Expert 3 for Mac (macOS) Updates: Get continuous support and bug fixes. Additional new features may come at an extra cost. PDF Expert One-Time Purchase normally costs $139.99, but you can pick it up for just $79.97 for a limited time, that represents a saving of $60 (42% off). For a full description, specs, and license info, click the link below. Get PDF Expert for just $79.97, or learn more Although priced in U.S. dollars, this deal is available for digital purchase worldwide. We post these because we earn commission on each sale so as not to rely solely on advertising, which many of our readers block. It all helps toward paying staff reporters, servers and hosting costs. Other ways to support Neowin Whitelist Neowin by not blocking our ads Create a free member account to see fewer ads Make a donation to support our day to day running costs Subscribe to Neowin - for $14 a year, or $28 a year for an ad-free experience Disclosure: Neowin benefits from revenue of each sale made through our branded deals site powered by StackCommerce.
    • It all went down hill after he retired from the ring, nothing really to do with him being a trumpster (as are most wrestlers). Hulk in general was a bad person after his retirement.
    • Debian switches to 64-bit time completely to avoid Y2K38 disaster by Usama Jawad Some of you may remember the Y2K problem, where the world expected airplanes to fall from the sky as soon as we reached the year 2000, primarily because many software applications at that time typically just used the final two digits of each year to store calendar year data, which meant that the year 2000 was indistinguishable from the year 1900. Fortunately, we were able to avoid the 2K problem, thanks to the tireless efforts of many software vendors and engineers. Now, we are a few years away from a similar issue, and it looks like the Linux distro Debian wants to solve that problem right now in its own operating system. Basically, older 32-bit architectures will face the Y2K38 problem in the year 2038. This is because the signed representation of Unix datetime values will overflow the 32-bit space, which would cause bugs in associated software. Debian is a pretty old distro with its first release dating back to 1993, so the maintainers say that a lot of sensitive computing is still happening on 32-bit architecture. Although there are still roughly 13 years to go before we reach 2038, developers want to proactively tackle the problem rather than having to scramble at the last minute like with Y2K, according to The Register. Another name for Y2K38 is the Unix Epochalypse, since it impacts systems that store datetime values in the Unix format within a signed 32-bit space. On January 19, 2038, 03:14:07 UTC, this space will overflow. As such, Debian maintainers will use 64-bit time_t formats even on 32-bit architectures starting with the release of Debian 13 "Trixie". This is not a small change, as maintainers found the use of the time_t variable in random places across 6,429 packages. The maintainers went on to say that: This may be a breaking change for some applications, so it is important to test your program's response to the time_t variable switch by leveraging the Debian wiki. Interestingly, Y2K38 may also impact certain older Windows programs and out-of-support Windows operating systems.
    • I hope they programed its eyes to turn red when it becomes evil, that is an important feature for any AI representation.
      CyberCeps666 earned a badge
    • Very Popular
      d4l3d earned a badge
      Very Popular
      Stephen Leibowitz earned a badge
      Snake Doc earned a badge
      Philsl earned a badge
      163
      124
