Hi all , i'm quite a beginner in C# language , i wanted to write a program that uses OOP and requires the user to input an amount of cash and another amount to take it from cash , if the cash is lesser than the amount , it will display "Not enough cash." message . very simple ... here's my code :
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
namespace WindowsFormsApplication1
public partial class Form1 : Form
public Form1()
InitializeComponent();
guy1 = new Guy();
double x;
if (double.TryParse(textBox2.Text, out x))
guy1.guycash = double.Parse(textBox2.Text);
guy1.guyname = textBox1.Text;
Guy guy1 ;
private void button1_Click(object sender, EventArgs e)
label5.Text = guy1.TakeCash(double.Parse(textBox3.Text)).ToString();
And here's the Guy class code :
using System;
using System.Linq;
using System.Text;
class Guy
private string name;
private double cash;
public string guyname
get { return name; }
set { name = value; }
public double guycash
get { return cash ; }
set { cash = value; }
public double TakeCash(double amount)
if (cash > amount)
cash -= amount;
return cash;
else
MessageBox.Show("Notgh Cash.");
return 0;
ok , now bear with me please , using this in Public form1()
requires that a numeric value must exist in textbox2 when the form loads up , but i want to leave it empty so that the user can enter a number in it !
if i left it empty the double.TryParse will return false and the whole program will broke since there will be no control holding guy1.guycash value ..
smokn
if (double.TryParse(textBox2.Text, out x)) { guy1.guycash = double.Parse(textBox2.Text); }
any help is appreciated , thanks in advance :)
https://www.neowin.net/forum/topic/883536-cneed-help-converting-empty-string-to-double/Share on other sites
2 answers to this question
