Need help resolving possible XP malware issue
Yesterday evening, I was using Internet Explorer (8) to look at MySpace. My computer has typically been slow when accessing that site. I was trying to scroll to the top of the page, but Internet Explorer was taking a long time to process that scroll command. I'm not sure if I either closed the browser window or if it crashed, but all the sudden "XP Security Tools" launched on it's own and started scanning the harddrive. By the time it was done, it found 36 issues which included worms and trojans.
In terms of firewall software, in the past, I had Norton Personal Firewall (along with Norton Anit-Virus). Those products were the older versions, and eventually support for them ran out. At some point, the Windows Firewall application decided to turn itself off and then became disabled. Attempts to open the Windows Firewall resulted in XP Security Tools opening. It seems that I have to pay to remove these infections. What I am concerned about is that XP Security Tools may be giving me false information in order to make me pay for a subscription. I don't see how between accessing MySpace, Facebook, and other known sites, that my computer could have picked up all this stuff that Security Tools is identifying.
I managed to update Spybot Search and Destroy and ran the scanner. A few issues were identified and I fixed those issues. My computer is now at the point where I can't launch InternetExplorer without getting a warning from XP Security Tools. I left my computer on overnight and kept hearing "popping sounds" like applications in the system tray opening and closing or XP notification bubbles showing on the desktop. I've since turned the computer off and have left it off.
So, what is this XP Security Tools -- is that part of the Windows Updates that have included Windows Malicious Software Removal Tool? There doesn't seem to be a way to turn off the security tools because all the settings are greyed out.
Use Combofix from bleepingcomputer. Run this then run Malwarebytes. Download ATF cleaner and let it run. It will act like it is not responding but it is working, so wait. Just let it run and it will clean out your temp files. Download ccleaner and then let that run. be careful as it can remove thing that you dont want to remove. Delete all of your restore points as it is a big place for your virus to hide as it is protected. Post back and let me know how that goes.
XP Security Tools - is the virus, do not pay for anything.
Follow these instructions for removal. Then run Malwarebytes Anti-Malware, and if you have Avast Anti-Virus installed, Run a "Boot Scan" after.
For XP
1. Boot in safe mode (F8 at POST screen)
2. Click start > Run > type msconfig and press enter > click the
startup Tab and untick everything apart from the Anti-Virus > Press ok and
close that, but don't restart yet
3. Click start > Computer > Tools > Folder options > View Tab > Show
hidden files and folders
4. Click C:\ > Documents and Settings > "Account users name" > Local Settings >
Temp > and select all (Ctrl + A) and delete all (Shift and Del) (Do this for
each account holder folder (Account users name)
5. Click start > C:\>Windows > Temp > Select all > Delete
6. Click start > C:\>Windows > Prefetch > Select all > Delete
7. (Internet Explorer 7 + 8) Open IE > Click Tools > Options >
Advanced Tab > Reset and Check the "Delete personal settings" tick box
8. Click start > Run, type in regedit, press enter, navigate to "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run"
and delete all entries in the right pane apart from the Anti-Virus, Navigate to "HKEY_LOCAL_MACHINE\SOFTWARE" and to "HKEY_CURRENT_USER\Software"
look down the list for the XP security Tools and delete any entries, close regedit, Reboot
For Vista and 7
3. Click start > Computer > Organise > Folder and Search Options >
View Tab > Show hidden files and folders (For Vista it may be the same menu
as XP, I don't have a Vista machine to check)
4. Click C:\ > Users > "Account users name" > AppData > Local > Temp >
and select all (Ctrl + A) and delete all (Shift and Del) (Do this for each
XP Security Tools is not a real anti-virus but a fake ransom application :
Remove Fake Antivirus : http://freeofvirus.blogspot.com/2009/05/remove-fake-antivirus-10.html (portable)
Windows ?Antivirus? to Avoid at All Costs : http://news.softpedia.com/news/114-Windows-Antivirus-to-Avoid-at-All-Costs-130245.shtml
Microsoft has put together a list containing no less than 114 AV rogues which are detected by the company?s antivirus products, including Microsoft Security Essentials, Forefront Client Security, etc. It is important to note that the list contains only the official label provided by the software giant. Each of the items featured below come in a variety of packages and under a plethora of brands, which actually makes the number of fake antivirus in the wild much larger
Phenom II: I followed the steps you listed, and I think "XP Security Tools" is gone. I didn't see it listed in in the registry under "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run"
or "HKEY_LOCAL_MACHINE\SOFTWARE" and to "HKEY_CURRENT_USER\Software"
    • Lmao. Cries about not playing those games not installed and yet don't ever want to touch them.
    • If I want to merge folder trees that have a similar structure, Beyond Compare is always my first choice. It's not free but it's awesome. If I want to just scan a whole drive/folder and find duplicates that are taking up space, I like Czkawka.
    • Claude Code gets throttled as Anthropic rolls out fresh usage caps by David Uzondu Claude Code, the AI-in-terminal utility developed by Anthropic and launched back in February, is getting updated usage limits following weeks of user complaints about being abruptly cut off. Many developers on the "$200/month Max plan" found their access blocked after just a few requests, with no explanation from the company. In a recent thread posted to X, the AI lab explained that it has seen "unprecedented demand since launch," pointing to some of its heaviest users who were running the tool continuously in the background 24/7, with one person reportedly consuming tens of thousands of dollars in model usage on a single $200 subscription. Anthropic also claimed that some users were violating its usage policy by sharing and reselling accounts, which impacts system capacity for everyone. These factors all led the company to announce new weekly limits that will be added on top of the existing five-hour caps, effective August 28. Max plan subscribers will have the option to buy additional usage at standard API rates if they hit their cap. Here's what the new weekly limits look like: Pro Plan ($20/month): An estimated 40 to 80 hours of usage with the Sonnet 4 model. Max Plan ($100/month): An estimated 140 to 280 hours with Sonnet 4 and 15 to 35 hours with the top-tier Opus 4 model. Max Plan ($200/month): An estimated 240 to 480 hours with Sonnet 4 and 24 to 40 hours with Opus 4. Per TechCrunch, the company provided these hour-based estimates, noting that the actual numbers may vary based on the size of a project's codebase. What's interesting is how this new structure compares to the old marketing. Anthropic previously advertised its $200 Max plan as offering 20 times more usage than the Pro plan. Based on these new hourly estimates, that multiple is now closer to six. It is possible the 20x figure still applies when measured in tokens or raw compute, but, according to TechCrunch, the company has not clarified that point.
    • I don't give a rat's f### what Trumpette, the Putin puppet likes!
      Gladiattore earned a badge
      NeoWeen earned a badge
      Doreen768 earned a badge
      165
      107
