- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
davjak
I just thought this was worthwhile sharing. There is a program called SWiSH that allows you to create Flash Animations without having the Flash program. I've used it myself and I love it. takes less than 5min to create a simple animation.
a statement from there from page reads as:
"What is SWiSH?
SWiSH is an easy to use tool for creating Flash animations. Because SWiSH exports the same animation format as Macromedia Flash? more than 95% of internet users can view SWiSH movies without installing a plug-in. SWiSH makes it easy to create common effects such as animated text, interactive menus, and web site intros. Best of all, SWiSH is only $30"i>
I do believe those are $US dollars.
Anyways. I just thought it was worth sharing with everyone.
http://www.swishzone.com
Dave
https://www.neowin.net/forum/topic/89-swish-create-flash-without-flash/Share on other sites
1 answer to this question
