[ASP.NET 3.5] Custom Paging for ListView Control
Hello,
I'm trying to create a custom paging for a ListView I have. I don't want to use Data Pager since it relies on the viewstate and I cannot afford to fetch all records at once (1 million++ records).
I tried to read a lot of this subject but I couldn't find anything that I can use. What I currently have (since the project is still in development and not production) is the data pager inside the Layout Template for the ListView Control.
Any helps, tips are welcomed. I'm completely stuck!
10 answers to this question
Your problem doesn't lie within the pager. It lies in the records you are retrieving. By building a more efficient search filtering front end you can retrieve fewer, more relevant results.
Build a search criteria page to allow the user to restrict the results. If the dataset is merely informational data, then filter on a default such as limit to only current year, or 6 months, or top 500.
Not only will doing the above make the end user happy, but your DB server will thank you as well.
In that case, I would have a talk with someone with knowledge on servers who is involved with the project.
Obtaining such results consumes the DB processing.
If I were stuck in such a scenario, I would still cheat. I would hide the pager. I would then create a series of buttons underneath the display such as:
"Pages 1-10" "1" "2" ... "10" "Pages 11-20"
Then only grab enough results to fill 10 pages (ex. 20 results per page x 10 pages = 200 results).
Upon clicking "Pages 11-20", query and filter so you get results 201-400, and change the text of the buttons.
I actually found some code on the internet to deal with paging (a stored procedure that takes startIndex, maxdisplay ... etc ..) It worked fine, but when I use ObjectDataSource you need to supply the SelectCountMethod, and when do that the select parameters gets messed up (I think there is a bug or something since the data source cannot differentiate between the SelectMethod and the SelectCountMethod).
Can we see what code you have so far, this works for me:
        <asp:ObjectDataSource
            ID="ObjectDataSource1"
            runat="server"
            EnablePaging="true"
            TypeName="Test.CustomerSelector"
            SelectMethod="GetPageOfCustomers"
            SelectCountMethod="GetCountOfCustomers"
            StartRowIndexParameterName="page"
            MaximumRowsParameterName="count" />
With an example selector:
    public class CustomerSelector
        public List<Customer> GetPageOfCustomers(int page, int count)
            return GetCustomers(count).ToList();
        public int GetCountOfCustomers()
            return 100;
        private static IEnumerable<Customer> GetCustomers(int count)
            for (int i = 0; i < count; i++)
                yield return CreateCustomer();
        private static Customer CreateCustomer()
            return new Customer { Title = "Mr", Forename = "Matthew", Surname = "Abbott" };
It's important to note that the function of the SelectCountMethod is not the same function as the SelectMethod, the SelectCountMethod simply gets the total number of entities. The SelectMethod is the method that you want called with your paging instructions.
*BUMP*.
I'm sorry for this long delay. This IS NOT WORKING AT ALL :'(. Here's the damned error that I'm always getting:
[i]ObjectDataSource 'obj' could not find a non-generic method 'GetItemsCount' that has parameters: txtSearch, letter, displayType.[/i]
this is the code that I have:
the object data source:
	<asp:ObjectDataSource ID="obj"
 	EnablePaging="true"
 	runat="server"
 	SelectMethod="GetItems"
 	SelectCountMethod="GetItemsCount"
 	MaximumRowsParameterName="pageSize" StartRowIndexParameterName="startRowIndex"
 	TypeName="App_Code.Items">lt;SelectParameters>
 	<asp:ControlParameter ControlID="txtSearch" Name="txtSearch" PropertyName="Text" Type="String" />
 	<asp:ControlParameter ControlID="menu" Name="letter" PropertyName="SelectedValue" Type="String" />
 	<asp:ControlParameter ControlID="chk" Name="displayType" PropertyName="SelectedValue" Type="String" />
 	</SelectParameters>
	</asp:ObjectDataSource>
function signature:
public List<object> GetItems(string txtSearch, string letter, string displayType, int startRowIndex, int pageSize)
public int GetItemsCount() { return 500; }
the stored procedure:
ALTER PROCEDURE [dbo].[GetTitles]
 	@Alpha nvarchar(255),
 	@Letter nvarchar(20),
 	@DisplayType nvarchar(20),
	 @startRowIndex int,
	 @pageSize int
The object data source is bound to a ListView control if that helps? I'm getting frustrated. HELP ME!!!!!!
  On 24/05/2010 at 16:08, sbauer said:
Why are using an ObjectDataSource? Why don't you just code it yourself?
yeah, that's what I did :-). the problem is already solved, but I want to know why the ObjectDataSource is not differentiating between SelectMethod and SelectCountMethod. Is this a bug or something?
I think the reason why it's having trouble, is that the two methods should be designed to accept the same parameters. E.g.
GetItems(string txtSearch, string letter, string displayType, int startRowIndex, int pageSize);
and
GetItemsCount(string txtSearch, string letter, string displayType);
The reason for this is you should expect the GetItemsCount method to process the same arguments as the GetItems method, because it should be providing a count of how many items the GetItems method should return. If you had a method which doesn't accept the same parameters, how can you know that the count being returned is the actual count of items from GetItems if it is not accepting the same arguments?
    • Azure Linux 2.0 reaches end of life, requiring AKS Arc users to upgrade by Paul Hill Microsoft has warned that Azure Linux 2.0, used in Azure Kubernetes Service (AKS) enabled by Azure Arc, will reach its end of life on July 31, 2025, necessitating users to upgrade. After this date, Microsoft will no longer provide updates, security patches, or support for Azure Linux 2.0. The longer it is used after this date, the more vulnerable systems will become due to a lack of patches. Azure Linux 3.0 brings significant upgrades to core components that enhance performance, security, and the developer experience. The Linux kernel is upgraded from version 5.15 to 6.6, bringing performance and hardware compatibility improvements. The Containerd package has been updated from version 1.6.26 to 1.7.13, improving container management. The SystemD package has been upgraded from version 250 to 255, streamlining system and service management, and OpenSSL has jumped from version 1.1.1k to 3.3.0, providing enhanced encryption and security. Azure Linux 3.0 also brings more packages and better tooling. Major versions of Azure Linux are typically supported for three years, with Azure Linux 3.0’s EOL projected for Summer 2027. It became generally available in August 2024.Microsoft said that users must migrate to Azure Linux 3.0 by upgrading their Azure Local instances to the 2507 release when it becomes available. After the Azure Local instance has been upgraded, users can then upgrade their Kubernetes clusters. Microsoft gives you the option to remain on the same Kubernetes version during this upgrade by providing the same version number on the aksarc upgrade command. After upgrading, you can verify the kernel version on your Linux nodes by adjusting the file path in this command: kubectl --kubeconfig /path/to/aks-cluster-kubeconfig get nodes -o wide This upgrade is mandatory for continued support. If you want to learn more, check out Microsoft’s announcement which also includes how to reach out to the AKS Arc team if you need to.
    • PDF-XChange Editor 10.6.1.397 by Razvan Serea PDF-XChange Editor is a comprehensive PDF editor that allows you to create, view, edit, annotate, and digitally sign PDF documents with ease. With advanced features like OCR, document security, and PDF optimization, PDF-XChange Editor is a powerful tool for both personal and professional use. Whether you need to edit text, images, or links, or add comments, stamps, or watermarks, PDF-XChange Editor provides all the necessary tools to make your PDFs look perfect. Additionally, it supports a wide range of file formats, including PDF, XPS, and DOCX, making it easy to convert and share your documents. PDF-XChange Editor key features: Edit text and images in PDF documents Add and remove pages from PDF files Annotate and markup PDFs with comments, highlights, and stamps Use OCR to convert scanned documents into searchable text Create and fill out PDF forms Sign and certify PDF documents digitally Add and edit hyperlinks within PDFs Extract text and images from PDF files Batch process multiple PDF files at once Customize the interface to your preferences Work with multiple documents in tabs Convert PDFs to other formats such as Word, Excel, and HTML Use advanced redaction tools to permanently remove sensitive information Add customizable headers and footers to PDFs Merge multiple PDF documents into a single file Split PDF documents into multiple files Add watermarks to PDF documents Use the measurement tools to calculate distances and areas in PDFs ....and much more PDF-XChange Editor 10.6.1.397 changelog: New Features Added offline support for MIP-protected documents. Bug Fixes & Improvements Fixed some security and stability issues. Click here for further information. Fixed an issue with DocuSign when a document name is very long. Fixed a very rare issue when opening password-protected files. (46285) Fixed an issue with moving content items in some cases, where arrow keys became unexpectedly deselected under certain conditions. (T# 7476) (40279) Fixed an issue with disabling the Zoom In/Out tool after using the Snapshot tool. (46330) Fixed an issue with an unintentional button press when the Autoscroll command was executed under specific conditions. (46289) Fixed an issue with resetting object selections when panning with mouse middle button. (46358) Fixed an issue with adding a highlight when starting to drag directly above the comment that is itself above base content text. (46410) Fixed an issue with adding a guideline by dragging from the ruler while a text comment or base content is being edited. (45858) Fix the call to app.clearTimeOut after the timeout handler was executed and the associated timer was unregistered. Improved static XFA support. Fixed an issue when adding Insert/Replace text markup comments to the first word in a text line. (47120) For a complete list of changes and more detailed information, please refer to the official PDF-XChange Editor Version History. Download: PDF-XChange Editor (64-bit) | Portable ~300.0 MB (Shareware) Download: PDF-XChange Editor (32-bit) | Portable ~200.0 MB Download: PDF-XChange ARM64 | 264.0 MB Download: PDF-XChange Portable @PortableApps.com | 97.0 MB View: PDF-XChange Editor Website | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • many people specially intel users stick with 23h2 because for some 24h2 have degraded performance, meanwhile they took 4 years to fix ryzen performance, amd and microsoft put the work to optimize but now crippling intel. for me windows 11 it feels like a beta OS, its not stable or reliable, every patch tuesday you have to pray that they dont break something.
    • Hi all! My motherboard is Gigabyte x570 Gaming X, and believe it or not I just realised it has two M2 slots 😅 So I wanna buy a new SSD, which would mostly be used for gaming. What would you recommend I buy? Is 990 Evo Plus good choice?
    • Explorer
      DougQuaid went up a rank
      Explorer
      MIghty Haul earned a badge
    • Collaborator
      KD2004 earned a badge
      Collaborator
      ataho31016 earned a badge
      140
      127
