Using DSquery to find member of in AD
I think you want to use dsget. but I don't think it will do what you are looking for. what you want are two different things. One is to scan active directory for group membership the other is to scan folders for directory accessability/permissions. This is where network design really comes into play and understanding how to build one. It sounds as if you are taking over someone elses mess and trying to figure it out, all I can say is get your clicker going. Take a look at what is being shared. You can use the perms command to be able to see what permissions x user has over the computer/server. perms is part of the 2003 resource kit which is free to dl from microsoft.
There is probably a third party tool that has the capability you are looking for, and it will more than likely cost.
How I would do it is look at the groups, find out the members of each group, find out what these members need access to. Look at the shares, see who has access to each share (this can be done by right clicking on my computer and clicking on manage, going into shared folders, then going into shares you can easily see all of the shares on one computer and you can easily manage the shares from here). It is a lot of work, but so is reading a text file and figuring out how to create said text file. Bottom line, it isn't easy, I have done this hundreds of times over (taking over a mess).
you need to pipe your commands... try something like this
dsquery user -name "*UserName*" | dsget user -memberOf
what this will do it query AD for a specific user and take the output of that and list what groups the user is a member of.
if you do dsget user /? it will give you everything you can get about the user as well.
Hope that helps
I think point sc302 was trying to make - is sure you can find the group memberships of a user, but that is not going to tell you where those groups have permissions or what they are, etc.
You might want to check out
http://technet.microsoft.com/en-us/sysinternals/bb664922.aspx
and
http://technet.microsoft.com/en-us/sysinternals/bb897332.aspx
and
was I not clear on that?
No you were clear, atleast to me - but I took it as the other poster did not catch the meaning of your post, atleast he made no mention that group membership will not give him what I took as what the user was after.
"permissions, directory access, groups etc."
    • KDE Plasma 6.5 will notify you if your printer's ink is low by David Uzondu This week, the KDE team continued work on the upcoming Plasma 6.5.0 as well as Plasma 6.4's fourth bug fix release, 6.4.4. As usual, both Plasma versions saw several UI tweaks, bug fixes, and performance improvements. The most notable changes are discussed in this article. Let's start with Plasma 6.5. The desktop environment is getting a useful feature that tells you when your printer is low on ink. This works by having the system check the Common Unix Printing System, or CUPS, for marker levels after a print job is created or completed. CUPS stores attributes like marker-levels in its printers.conf file, and once a level is determined to be low, it triggers a marker-supply-low-warning that Plasma will now use to inform you. UI improvements scheduled for 6.5 include disabling key repeat for certain global shortcuts, like toggling Overview, to prevent rapid screen flashing that could be a seizure risk. There is a better "Someone started sharing this screen" notification that now appears only after a connection is fully established. You will also find standard KDE styling with the "Confirm deleting network connection" dialog, and more consistent spacing in the Global Menu widget. As for bug fixes in 6.5, a layout bug that caused visual overflow in the printer setup page has been corrected. An issue that stopped you from using the virtual keyboard in the Application Dashboard search field is fixed, and XDG portal-using apps can now request screencasts of new virtual outputs. Finally, the clipboard configuration window's size and position information has been moved from the state config file to the settings file. Moving on to 6.4.4, the hitboxes for desktop items now correctly match their visual styling. This means no more accidentally selecting an invisible box around a file. And when you mark a notification as low priority, it will now correctly appear in your history if it arrived during Do Not Disturb mode, so it does not just vanish. If you're experiencing a Kwin crash on login, particularly in a QEMU virtual machine, 6.4.4 has a fix for that on the way. Other bug fixes 6.4.4 brings include: A fix for the Global Menu widget's single-button mode for X11 users. The search field in the Wayland version of the Global Menu widget works again. An annoying bug in the Global Shortcuts XDG portal that made apps think they had no shortcuts has been resolved. Plasma Browser Integration's built-in Share feature has been repaired. Plasma 6.4.4 will drop on the 5th of next month. You can find more details on the official KDE Blog.
    • I just remember wondering how she was ever a bridge officer at all with all of her insufferable insecurities. I am sure she's a wonderful person in real life, but the character was poorly written. They even had to dedicate a whole episode to her being forced into taking the responsibility of leading cadets out of a problem of some sort as if to show how she is "growing" into her function. Never bridge officer material and I just rolled my eyes at her scenes and eventually stopped watching the show altogether, but also because of all the lead character's cry/whisper/talking that frustrated me.
    • Didnt know it was coded/decoded so my bad.
    • Why isn't it more widespread then? What about people that like PC gaming and don't want/don't own a console? MMO gaming/professional work with specific software aren't "edge cases".
      Homayoun Hotak earned a badge
      Profit earned a badge
      hhgygy earned a badge
      NIKI77 earned a badge
      168
      123
