- 0
[VB.net] Help About Cursor
Asked by
Evanescence,
Recently Browsing 0 members
Posts
By CloudEngineer · Posted
Wouldn’t it be better to disable global c states to improve latency at the cost of marginally higher heat and power usage? -
By nekrosoft13 · Posted
I recently bought a brand new Intel 200 series laptop with 16GB, 512GB NVME (now 2TB) with 14 inch OLED screen for $450. Not the fastest laptop in the world, but the screen is great and laptop is small, just what I needed. -
By wolftail · Posted
They forgot to include this slide: "If I get a Mac I won't be able to play games, therefore I will have more time for my studies." -
By adrynalyne · Posted
It’s not desperation, it’s marketing. Companies do that… -
By hellowalkman · Posted
Some AMD Ryzen users can get free Windows performance boost with this simple system tweak by Sayan Sen AMD understands that there is a lot of demand for its X3D processors and for good reason too, since they offer some of the best gaming experiences. As such, the company plans to launch a new 6-core Ryzen 5 9600X3D for those who may not want to spend top dollar on a 9800X3D. What makes X3D special is the densely packed last level cache (LLC) wherein the L3 (level 3) cache is 3D die-stacked such that there is a whole lot of it that the cores can access on demand all within the smallest footprint. This is said to help with latency especially, and games happen to be quite sensitive to it since they are a mixed workload and so there is a lot of to-and-fro. However, despite that fact, users have noticed micro-stuttering and freezes on Ryzen X3D CPUs. Although there is no official fix, some of the affected users have managed to resolve the issues by tweaking a motherboard setting. The tweak is related to a setting called "GLOBAL C-STATE CONTROL" (it may be called something else by your motherboard vendor) and changing it to 'Enabled' from 'Auto' could fix stuttering and lag-related issues in games. If you are not familiar with them, Processor Power Management is done through Advanced Configuration and Power Interface (ACPI) P-states or C-states. While P-states or performance states handle CPU voltage-frequency scaling, C-states deal with CPU sleep states so that some of the CPU functions, which are not necessary at that moment, are disabled. The P-states and C-states work together to make the processor run more efficiently. It helps the OS and apps determine which cores can be parked. The Global C-state control setting helps users manage not only the DF and CPU core C-states but also the I/O C-states too. For those wondering, DF here refers to Data Fabric or AMD's high bandwidth Infinity Fabric interconnect between CPUs, GPUs, and more, on AMD systems. By default, this is set to "Auto" which also means that it is "Enabled" by default. However, in the case of X3D parts, Auto may set this setting to "Disabled" and thus manually toggling it to "Enabled" may be necessary. X3D processors, the dual CCD (core complex die) ones especially, have their V-cache on a single CCD. If the CPPC (Collaborative Processor Performance Control), which lets an OS like Windows control the "preferred core" and clock speed boost, isn't working optimally to assign the correct gaming CCD, then this fix could well work. Global C-State Auto: Global C-State Enabled: We ran a benchmark on our Ryzen 9 9950X3D to see if toggling the settings would make a difference, and well, it didn't in the case of AIDA64. However, since this is a synthetic test that measures cache and memory exclusively, we can't definitively conclude that the fix will also not make a difference in the case of games. Another remedy for stuttering is to disable the monitoring of the "Power percent" metric on MSI Afterburner if you have it on. This has been a long-known issue and in fact can help you even if you are not using an X3D CPU. Source: Reddit (link1, link2) via YouTube
Recent Achievements
DecaffKnight94 earned a badge
S.P earned a badge
adxnksd42031 earned a badge
aphanic went up a rank
Rising Star
GravityDead went up a rank
Contributor
Popular Contributors
Tell a friend
Evanescence
When i start my application i want my cursor to be in label1.text ;x i don't have idea how to do it ..... I tryed many things withouse result. p.p Sorry For MY Bad EN ;/
https://www.neowin.net/forum/topic/925788-vbnet-help-about-cursor/Share on other sites
9 answers to this question
