TaZeR Posted July 21, 2003 Share Posted July 21, 2003 Ok ive got this small problem but its annoying and I have no idea how to change it, you know how when you download a zip or something theres a box to check that makes it save it to a temp folder and just open the zip after downloading it, i checked that box by accident but now I want it back so I can just pick the location and save the whole zip. Can anyone please help me with this? Link to comment https://www.neowin.net/forum/topic/93258-need-help-with-something-in-ie6/ Share on other sites More sharing options...
gam_EZ Posted July 21, 2003 Share Posted July 21, 2003 Just start to download a big file so the dialog box is still showing and uncheck it, then cancel the download. Link to comment https://www.neowin.net/forum/topic/93258-need-help-with-something-in-ie6/#findComment-1063424 Share on other sites More sharing options...
TaZeR Posted July 21, 2003 Author Share Posted July 21, 2003 I cant the box doesnt appear because there is no save to window that appears it just starts downloading it by itself and just opens the file when its done. Link to comment https://www.neowin.net/forum/topic/93258-need-help-with-something-in-ie6/#findComment-1063486 Share on other sites More sharing options...
TaZeR Posted July 22, 2003 Author Share Posted July 22, 2003 bump Link to comment https://www.neowin.net/forum/topic/93258-need-help-with-something-in-ie6/#findComment-1064864 Share on other sites More sharing options...
uniacidz Posted July 22, 2003 Share Posted July 22, 2003 Before you download, make sure that the "Confirm open after download" option is selected. To verify this: 1. Click Start, point to Settings, and then click Control Panel. 2. Double-click Folder Options. 3. Click the File Types tab. 4. Scroll down to and click the .zip extension. 5. Click Advanced. 6. Verify that "Confirm open after download" is selected. Link to comment https://www.neowin.net/forum/topic/93258-need-help-with-something-in-ie6/#findComment-1064872 Share on other sites More sharing options...
Sweed Posted July 22, 2003 Share Posted July 22, 2003 Hmm..dont exactly know what u mean, but maybe this: Tools - Internet Options - Security - Cutom Level (left button) - scroll down until u see "Filedownload" and check activate it. Link to comment https://www.neowin.net/forum/topic/93258-need-help-with-something-in-ie6/#findComment-1065066 Share on other sites More sharing options...
uniacidz Posted July 22, 2003 Share Posted July 22, 2003 Well its pretty simple. Is easy, read it again. Link to comment https://www.neowin.net/forum/topic/93258-need-help-with-something-in-ie6/#findComment-1065126 Share on other sites More sharing options...
TaZeR Posted July 22, 2003 Author Share Posted July 22, 2003 heh thanks, who woulda thought its there but now I know for the future. Link to comment https://www.neowin.net/forum/topic/93258-need-help-with-something-in-ie6/#findComment-1066808 Share on other sites More sharing options...
