[Minefield preb6] Extensions/Plugins keep going missing
OK So I installed the Compatibility Reporter, Omnibar, Ad Block Plus, Echofon, and a few others, but everytime I restart Ad Block Plus, Echofon and others are missing, uninstalled.. this happens with any other extension I install too, only Omnibar and Compatibility Reporter stay installed :/
On Mac OS X 10.6.4 using the latest nightly.
I already tried deleting the extensions.sqlite .ini etc method, but that didn't work. I'm at my wits end!
Edit: Same happens with Plugins too.. Adobe Flash Player just installed, and after Minefield restarted its not installed :( :angry:
will stop unpacking extensions by default. Extensions with binary components or which use ctypes will need to be modified to add <em:unpack>true</em:unpack> in their install.rdf.
https://wiki.mozilla.org/Firefox/Planning/2010-09-01#Firefox_4_Beta_6
The above may help you.
i had a similar problem with the nightlies awhile ago, it eventually went back to normal after a couple weeks worth of updates, never was sure what caused it, you could try deleting the profile and making a new one, was too lazy to try it myself but it could work
  On 12/09/2010 at 02:53, Gary7 said:
Thanks, that must have been it because I installed Beta 5 and all is working :p
    • KDE's KClock is getting Wayland Picture-In-Picture support by David Uzondu The KClock app for KDE Plasma over the years has received a number of updates, like better integration with KRunner and a dedicated background service (kclockd) for managing alarms. Now, it looks like KDE devs want to add something cool: pop-out timers using the new Picture-in-Picture protocol for Wayland. Image: Kai Uwe Broulik This all started from a simple observation. Kai Uwe Broulik, a KDE developer, saw someone using a small timer window during a presentation and thought it was a good idea. The problem is that achieving this kind of "always on top" behavior is handled differently between the old X11 display server and the newer Wayland. With X11, an application could pretty much do whatever it wanted. If a program wanted to draw a drop-down menu, it would just create a borderless window, place it in a specific spot, and grab all user input. Wayland operates on a different philosophy. As Broulik notes, under Wayland, the application describes what it wants, and the compositor gets to decide how to handle it. A drop-down menu is an XDG Popup. The application tells the compositor which button spawned it, and the compositor handles the placement and behavior. This is much more secure and consistent. It also means an application cannot just decide to keep its window on top of everything else. This restriction prevents a web browser from implementing an overlay video player under Wayland. To get around this in a standardized way, a proper Wayland support model for Picture-in-Picture, or PiP, was needed. Enter the xx-pip-v1 protocol. It is a new protocol designed specifically for creating floating PiP windows, and KWin, Plasma's compositor, recently gained support for it. Because it is an experimental protocol, its use is gated behind an environment variable, KWIN_WAYLAND_SUPPORT_XX_PIP_V1. A new protocol is fine for demos, but it needs a real application to find its weaknesses. So Broulik implemented it in KClock. This work allows KClock to offer pop-out timers and even a pop-out stopwatch in a small PiP window. The user could get system-wide options to control where the PiP window appears, or if it appears at all, and have that setting apply to every single application that uses the protocol. You can check out the merge request on GitLab for more technical details about this feature.
    • Nothing of course; it is just a classic syndrome of MAGA pathology.
    • They use it to assessment's in the UK already. Have a friend who said they basically feed response's and prompt during assessment's for many mental health conditions now (essentially tick boxes these days enough ticks and you got it) the AI can prompt questions to ask if its unsure how to score something. It's really good at recognising fractures and broken bones also.
    • Look it more of another tool in your toolbox. The good doctors will use tools like this to aid in proper diagnostics and help their patients. There will be some doctors out there that will rely on it and never actually learn how to be a doctor. My wife deals with chronic illness, seizures, and MS. If this would help her doctors to get her on a better path to recovery, I'm all for it. She does take about 4-5 different medications daily and no one wants to play Russian roulette to figure out which meds she really needs.
    • I'm currently wearing Hoka Clifton 8.  It's a good shoe.
      CHUNWEI earned a badge
      TIGOSS earned a badge
      henryj earned a badge
      CarolynHelen earned a badge
      196
      81
      Som
      77
