Problem with the CMD Prompt in XP!
Hey Everyone, I was hoping that you guys could help me out with a problem I've been having for the past few weeks.
For some reason whenever I enter the command prompt in windows xp pro, via run>cmd and type in a program such as telnet or winipcfg(from 2k pack), etc. or any other program, the following message appears:
'<some program>' is not recognized as an internal or external command, operable program or batch file.
This error message only occurs when I type in the program in a directory where the program isn't located, ie typing in Telnet under C:\.
Does anyone have a solution for me :) Or is this suppose to happen in xp? Perhaps I activated some feature I shouldn't have :huh: Any help would be appreciated :)
Thanks,
Evolution
https://www.neowin.net/forum/topic/93820-problem-with-the-cmd-prompt-in-xp/
What's your Path set to? At the very least, you should have "C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem" assuming your Windows directory is C:\Windows. You can see your Path variable by opening a command prompt (ironic, huh?) and typing "echo %path%" or typing "set" and looking for the Path value.
--ps
:ninja:
Seems to me like your path has been deleted. try setting your path from within a dos command promt first. if it works, it will work until you reboot. you may have to create a batch file to run everytime u reboot to retype your path. i'm not sure what you did to delete it, but you must have done something.
to set the path just type 'set path=' followed by your path. for example:
set path=C:\windows
if you want to set multiple paths, seperate them by a semi-colon. For example:
set path=C:\windows;C:\windows\system32;C:\windows\command
Hope this helps ya.
    • 65-inch Samsung Crystal UHD DU8000 series Smart TV is back to its lowest price by Fiza Ali Amazon is once again offering the 65-inch Samsung DU8000 Series Smart TV at its lowest price. The DU8000 offers a Crystal UHD LED panel that delivers a native 3,840 × 2,160 resolution while the Crystal Processor 4K employs AI‑driven upscaling to optimise lower resolution content to 4K clarity. For picture quality, the DU8000 supports a comprehensive High Dynamic Range (HDR) suite including HDR10, HDR10+, and HLG alongside Film and Filmmaker Modes. Dynamic Crystal Colour enhances colour volume for richer, more accurate hues, and Mega Contrast with UHD Dimming boosts depth and definition in both bright and dark scenes. Furthermore, the Motion Xcelerator engine maintains smooth motion clarity at 60Hz. Gaming on this model should be good with Auto Low Latency Mode (ALLM), Variable Refresh Rate (VRR) support, and HGiG customisation, promising minimal input lag and fluid frame rates. HGiG (HDR Gaming Interest Group) customisation ensures that HDR content in games is displayed as the developers intended by applying standardised tone mapping tailored to gaming, rather than general HDR video settings. This helps prevent overly dark shadows or blown-out highlights, maintaining detail and visual consistency across a wide range of game environments. Moreover, a dedicated Gaming Hub offers streamlined access to cloud gaming services and console content. Audio is driven by a 20W (2‑channel) system featuring Samsung’s Object Tracking Sound Lite (OTS Lite) and Q‑Symphony which synchronises TV speakers and compatible soundbars for multidimensional sound without overlap. Adaptive Sound analyses each scene to optimise dialogue and effects, while dual‑device Bluetooth pairing allows wireless connection of headsets or external speakers. Furthermore, the Tizen Smart TV platform offers a built‑in Bixby voice control and compatibility with Alexa and Google Assistant. Connectivity options include three HDMI 2.0 ports (with eARC/ARC), two USB‑A ports, Ethernet, optical digital audio out, RF in, and dual‑band Wi‑Fi 5 (802.11ac). Accessibility features include multi‑language Voice Guide, high‑contrast and zoom modes for low‑vision users, closed captions and sign‑language zoom for the hearing impaired, and slow‑repeat buttons and a remote‑control app option for those with motor impairments. 65-inch Samsung Crystal UHD DU8000 Series HDR Smart TV: $399.99 (Amazon US) This Amazon deal is US-specific and not available in other regions unless specified. If you don't like it or want to look at more options, check out the Amazon US deals page here. Get Prime (SNAP), Prime Video, Audible Plus or Kindle / Music Unlimited. Free for 30 days. As an Amazon Associate, we earn from qualifying purchases.
    • I'm not exactly sure where to post this, so move it if needed. Where can I get a Windows 11 Pro upgrade key cheap? The one I bought through Neowin Deals no longer works, and I just bought a new laptop & want to upgrade from Home to Pro.
    • Except Rolling Releases. No EOL, continuous updates.
    • True, Windows 95 could barely run on systems made in 1995. Two responses, first, people did complain in the 90s about how quickly software updates obsoleted hardware, so it isn't like it was fine then and not now. Second, it hits a little different when the requirement is seemingly arbitrary instead of a true resource requirement.
      Stephen Leibowitz earned a badge
      Homayoun Hotak earned a badge
      Profit earned a badge
      hhgygy earned a badge
      169
      124
