jquery colorbox (lightbox) implementation help
Hey all,
Alright so I need to implement 3 separate instances of colorbox on a single page. The situation I have things at the moment can't be avoided as I really don't want to re-do the whole layout of this site for colorbox implementation. Also you will see i'm linking to the same pictures in 2 instances, I wanted to get it working before i bothered setting up the pictures for each one. So bare with me here.
In the header I have:
        &lt;script type="text/javascript" src="/colorbox/jquery.colorbox.js"></script>     &lt;script type="text/javascript"&gt;
            $(document).ready(function(){
                //Examples of how to assign the ColorBox event to elements
                $("a[rel='colorboxrules']").colorbox();
                $("[rel='colorboxruleseaster']").colorbox();
                $(".cbyoutube").colorbox({iframe:true, innerWidth:425, innerHeight:344});
                //Example of preserving a JavaScript event for inline calls.
                $("#click").click(function(){
                    $('#click').css({"background-color":"#f00", "color":"#fff", "cursor":"inherit"}).text("Open this window again and this message will still be here.");
                    return false;
        &lt;/script&gt;
First instance, working like a charm:
&lt;a title="" rel="colorboxrules" href="/images/easter/gallery/1.jpg"&gt;&lt;img src="/images/main_menu/product3_big.jpg"&gt;&lt;/a&gt;
&lt;div class="eastergallery2"&gt;
&lt;a title="" rel="colorboxrules" href="/images/easter/gallery/2.jpg" /&gt;
&lt;a title="" rel="colorboxrules" href="/images/easter/gallery/3.jpg" /&gt;
&lt;a title="" rel="colorboxrules" href="/images/easter/gallery/4.jpg" /&gt;
&lt;a title="" rel="colorboxrules" href="/images/easter/gallery/5.jpg" /&gt;
&lt;a title="" rel="colorboxrules" href="/images/easter/gallery/6.jpg" /&gt;
&lt;a title="" rel="colorboxrules" href="/images/easter/gallery/7.jpg" /&gt;
&lt;a title="" rel="colorboxrules" href="/images/easter/gallery/8.jpg" /&gt;
&lt;a title="" rel="colorboxrules" href="/images/easter/gallery/9.jpg" /&gt;
&lt;a title="" rel="colorboxrules" href="/images/easter/gallery/10.jpg" /&gt;
&lt;/a&gt;&lt;/div&gt;
* not sure why that last </a> needs to be there... but the page breaks if i remove it.
** class eastergallery2 just tells the div to display : none
Ok so that one works perfectly, now for the second one. I am forced, due to the way I built the site to use the <map> tag to map links onto an image, this will not be changed, I will remove the gallery if need be. One of those mapped areas is meant to link to a second gallery and another one maps to a youtube video.
youtube video - works perfectly fine, no problem there.
photo gallery - only first photo is showing up.
&lt;a&gt;&lt;img src="/images/main_menu/product5_big.jpg" usemap="#sales"&gt;
&lt;map name="sales"&gt;
    &lt;area shape="rect" coords="445,12,635,76" href="/files/EasterFlyer2010.pdf" alt="Past Easter Sale Flyer" /&gt;
    &lt;area shape="rect" coords="445,92,635,165" title="" rel="colorboxruleseaster" href="/images/easter/gallery/1.jpg"/&gt;
&lt;a title="" rel="colorboxruleseaster" href="/images/easter/gallery/2.jpg"/&gt;
&lt;a title="" rel="colorboxruleseaster" href="/images/easter/gallery/3.jpg"/&gt;
&lt;a title="" rel="colorboxruleseaster" href="/images/easter/gallery/4.jpg"/&gt;
&lt;a title="" rel="colorboxruleseaster" href="/images/easter/gallery/5.jpg"/&gt;
&lt;a title="" rel="colorboxruleseaster" href="/images/easter/gallery/6.jpg"/&gt;
&lt;a title="" rel="colorboxruleseaster" href="/images/easter/gallery/7.jpg"/&gt;
&lt;a title="" rel="colorboxruleseaster" href="/images/easter/gallery/8.jpg"/&gt;
&lt;a title="" rel="colorboxruleseaster" href="/images/easter/gallery/9.jpg"/&gt;
&lt;a title="" rel="colorboxruleseaster" href="/images/easter/gallery/10.jpg"/&gt;
&lt;/div&gt;
    &lt;area shape="rect" coords="445,177,635,238" class="cbyoutube" href="http://www.youtube.com/v/[videoaddress]"  /&gt;
    &lt;area shape="default" nohref="nohref" title="Default" alt="Default"/&gt;
&lt;/map&gt;
&lt;/a&gt;
Ok so as I said, the second gallery with rel="colorboxruleseaster' is only showing the first picture. Any suggestions to get this working? Thanks in advance
0 answers to this question
There have been no answers to this question yet
    • AMD releases new Windows 10 and 11 chipset driver for Ryzen processors by Taras Buria Following a major firmware update for a TPM-Pluton security flaw, AMD has a new chipset driver for all of its supported Ryzen platforms and processors. Version 7.06.02.123 is now available for download, and it adds unnamed bug fixes and an important addition to the AMD PPM Provisioning File driver, which improves the security of the component. The security update in question is CETCOMPAT support for the AMD PPM Provisioning File driver. CET or Control-flow Enforcement Technology (CET) was introduced for Windows 10 versions 20H1 and 20H2 in early 2021. In a nutshell, it is an Intel-developed protection system that prevents malware from changing memory addresses (Shadow Stack) or redirecting programs to malicious code by ensuring they use only approved, safe locations (Indirect Branch Tracking). AMD brought CETCOMPACT support to parts of its Ryzen chipset driver suite (the driver you download and install is a set of different drivers serving different purposes that AMD lets you select on the first screen) in October 2024. Now, with driver 7.06.02.123, CET compatibility has been added to the AMD PPM Provisioning File driver, which is responsible for core parking and power management. Here is the list of updated drivers in today's release: Driver Version (Windows 10) Version (Windows 11) Changelog AMD PPM Provisioning File Driver 8.0.0.53 8.0.0.53 CETCOMPAT support is added AMD PMF-6000 Series Driver 24.0.6.0 24.0.6.0 Bug fixes AMD S0i3 Filter Driver 4.5.0.1020 4.5.0.1020 AMD 3D V-Cache Performance Optimizer Driver 1.0.0.11 1.0.0.11 AMD PMF-7040 Series Driver 24.2.6.0 24.2.6.0 AMD PMF-8000Series Driver 25.5.25.0 25.5.25.0 AMD PMF Ryzen AI 300 Series Driver 1 Not Applicable 25.6.28.0 AMD's latest Ryzen chipset driver supports 64-bit Windows 10 and 11 systems with the following motherboards: A-Series B-Series X-Series Threadripper AMD A320 AMD A520 AMD B350 AMD B450 AMD B550 AMD B650 / B650E AMD X370 AMD X470 AMD X570 AMD X670 / X670E AMD X870 / X870E AMD TRX40 AMD TRX50 AMD WRX80 AMD WRX90 You can download AMD Ryzen Chipset Driver 7.0.6.02.123 from the official support website. Full release notes and additional information is available on the same page.
    • I never got to experience BOB Hello even now because gaming laptops I bought always omitted the IR camera. And the standalone cameras for BOB Hello are super expensive
    • I wonder what $99 Chinese cellphone this phone will be based on. Whoever is dumb enough to buy the phone and/or get this service deserves everything they get.
    • Trump is a low-class guy who thinks painting everything in gold makes him look fancy.
    • Don't forget second season pass, that's not part of the superdeluxe edition.
    • Explorer
      treker_ed went up a rank
      Explorer
    • Apprentice
      CHUNWEI went up a rank
      Apprentice
    • Veteran
      1337ish went up a rank
      Veteran
      john.al went up a rank
      patrickft456 earned a badge
      174
