RA2 network problem
Hello,
I am having several issues with RA2 and was hoping you guys would be able to help me out.
I installed Red Alert 2; no problem at all. I can play the single player and it works fine.
But the problem arise when i want to play LAN against my brother.
If I am in the main menu and click "network" i go back to the main menu again, i cant open the network menu.
RA2 uses IPX/SPX for LAN.
I have windows 7 enterprise, so the IPX/SPX is no longer supported. (If I go to options -> network, it says "IPX is not available"
So I googled and found out i had to place a little wsock32.dll in my RA2 folder, then it would work.
But i placed that file in my folder and it is still not working. (if i go to options -> network now, i see 00 00 00 00 00)
Like here: http://logmeinwiki.com/images/c/c6/Image1_618.png
That should be good, but when i click network in the main menu now, i still go back to the main menu.
Does anyknow what the problem might be and how to resolve it?
https://www.neowin.net/forum/topic/963234-ra2-network-problem/
If you used the wsock.dll patch I don't know why it wouldn't work...
Here's the link: http://www.understorm.net/downloads
Are you both using the latest version of RA2? (1.006)
Link: http://www.filefront.com/845032/ra21006en.exe
Make sure with that patch that you run it in Windows 98 compatibility mode or else it won't install!
Are you playing this via Hamachi??
I hadn't actually looked at the link you posted before Candyman... I'm gonna try it out myself later on The First Decade.
To the original poster... are you using a standalone normal RA2 disc, or The First Decade? That could make a difference...
