- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
SiN_SiN
Hello everyone, I am really new to web-design so sorry if I sound silly.
I am currently creating a basic website which will consist of the follow:
Header/Logo
Navigation buttons
Jquery slider
Footer content
I have dicided to code using the 960 grid system and I am slowly understanding how to use it.
I have managed to input the header, and then directly underneath that the navigation buttons all within a grid_12 div
After this point I am stuck, i have been trying for days to input a jquery slider which will sit underneath the nav buttons and randomly change every few seconds but also show text alongside the image.
I thought it would have been easy to simply insert this slider http://nivo.dev7studios.com/#usage but it really isnt it just messes up.
I would really appreciate the help in doing this. thanks in advance
Sin
https://www.neowin.net/forum/topic/967204-960-grid-jquery-help/Share on other sites
7 answers to this question
