Counter Strike Problem
Okay, I got a new comp off newegg.com. YAY... specs below. Anyway, I wanted to install my favorite game of all time.... CS! (cheers) I hadn't played it for quite a while, but i installed it, and went up on the CS home page and got the 1.5 update (fileplannet took SOOOO long) ok so I got the update, everything is looking good and I'm ready to play. I go to join a game, and It starts to connect and then starts downloading a ton of files. Which appear to be sound files for the weapons, game files, etc. then it goes and goes and goes untill it gets to a file called "cm" i believe, and just sits there. I let it gor for over thirty minutes, and it didn't even start a download bar at the botton of the screen. I can't go without CS. Can someone help me? _ (I'm new to these boards.)
https://www.neowin.net/forum/topic/96799-counter-strike-problem/
I tried like 30 servers, heh no joke. I didn't install HL 1.1.1.0 I dont exactly knwo what that is. I went out and bought CS retail off the shelf a long time ago. I don't remember it having to dl all this stuff, the last time I installed it on my old comp. At first I thought it was just map downloads a junk, but its like m4a1 sounds and like sprites and stuff.
  Remote said:
I dont see why you would ahve to download all that crap. Did you try connecting to another server? Did you install HL 1.1.1.0 as well?
The "Crap" are server mods that allow sounds and stuff.
You can disallow downloads through the program hlves,
and yeah, have you tried connecting to other servers?
as for the download bar stopping, sometimes opengl stops drwaing the bar, so dont worry if it stops right at the end, its a normal occurance
not only do you need to update counter strike, but you need to update half life to version
1.1.1.0
The way to tell is on the bottom right of the menu screen.
Or easier yet do you have the multiplayer mod richochet?
  OPaul said:
He has CS retail. You don't need to update HL for that.
Well, it woudln't hurt ;)
I'm not familiar at all with retail version, But I was almost 100% sure you need to update half life, since it is the engine. unless the retail package was recently updated :huh:
Yes it would. You can't install a HL patch without having HL installed. CS retail doesn't include HL.
  m2x-ADMlN said:
?????? you jsut lost me. The CS retail installer is by Richochet. That's what I have.
One of the multiplyaer games called ricochet is included in the 1.1.1.0 update package.
Its like TFC.
Do you have it?
Wait a minute... that doenst make sense to me :p ,
because although cs retail is a stand alone, it still runs off the same valve halflife engine, therefore woudln't it need to be updated like everything else???
(Y) Opaul?
OH nevermind, I was wrong: :p found it
What do I need installed in order to play CS? If you have the MOD version installed, you need to have Half-Life installed, you need the latest Half-Life patch as well as the latest verson of Counter-Strike. If you are running the Retail version of CS, you will need to have CS installed from the CD, and the latest CS retail patch. You can get all of the files at Fileplanet's HL section and all needed CS files right here at our site on the downloads page.
OH btw,
Is this the error you get?
I'm getting the error
"could not load library C:\SIERRA\HALF-LIFE\/cstrike/cl_dlls/client.dll"
-- What is going on?
This is an error for the free Half-Life mod version of CS. This means that you don't have the latest Half-Life patch installed. Go here to download the latest HL patch file.
If you have broadband why not just use STEAM that will enable you to play CS 1.6 on a pletheroe of servers. And all the files needed are downloaded prior to playing (around 400mb).
AHHHHHH 1.6 is awful :cry:
I thought i woudl like it... WOW i did not.
The shield is fun for a while but really changes the whole game, not worth it (N)
Here is your solution:
You didn't update your HL before your CS. You must fully update your HL before updating your CS otherwise you will get the error:
"could not load library C:\SIERRA\HALFLIFE\/cstrike/cl_dlls/client.dll"
Just delete and reinstall that way.
Steam on the other hand, is a buggy piece of crap, and the 1.6 Beta still isn't as popular as 1.5 because 1.5 users know Steam is a buggy piece of crap, 1.6 full version is coming out soon anyways, and I'm hoping they will give us the option of Steam and client side updates.
