linksys router firmware upgrading problems
I have a BEFSR41 - EtherFast? Cable/DSL Router. Basically the same thing, cept I've got more ports on mine. Any ways, I upgraded mine with the latest firmware (1.40.2) today with no problems. I just downloaded the zip, unzipped the files, and followed the 5 or so steps for installation included in the PDF. I've never had much luck with the firmware update feature the router has, so I used the TFPT thing the zip came with and it worked like a charm.
    • I recently got a Chinese "WoWe" mini PC with a Ryzen 5 for like $150 brand new.  I got it to replace a raspberry pi and serve as my home VPN server and DNS Cache (PiHole).  I made a backup of its factory Windows 10 image with Clonezilla, then immediately nuked it and installed Debian. So if you wanna be extra paranoid just nuke whatever is on it and install your own operating system of choice and you should be fine. I wonder though, if I couldn't restore that image to a virtual machine and boot it up just to see what, if any shady stuff came on it.
    • I've written a Substack article where I talk about the expected release date for Debian 13 (August 9th) and cover some of the upcoming changes that will either affect me personally, or that I thought noteworthy.  You can read the whole thing here: https://open.substack.com/pub/gerowen/p/debian-gnulinux-13-trixie-is-just?r=54rcsd&utm_campaign=post&utm_medium=web&showWelcomeOnShare=true It's rather long and has several images that would probably exceed the attachment limit, but I'll copy and paste the first little bit of it here:
    • Too many middle managers at these big companies are the problem imo. The guys under them do all the work but these VPs or PMs fight with each other in order to move up the ladder which just messes things up.
    • Microsoft lifts another long-standing Windows 11 24H2 block, allowing more people to upgrade by Taras Buria In October 2024, Microsoft released Windows 11 version 24H2 with quite a long list of known bugs and upgrade blocks. Ever since, Microsoft has been slowly patching those bugs and lifting blocks one by one. Now, the company is removing another upgrade block, letting more Windows 10 and Windows 11 users upgrade to the latest version ahead of the upcoming end of Windows 10 support. The block in question affects PCs with Easy Anti-Cheat, an anti-cheat solution embedded in many popular games, such as PUBG or Fortnite. According to the official documentation, the compatibility issue affects systems with Intel's Alder Lake+ processors and the vPro platform with Easy Anti-Cheat drivers released before April 2024. Affected systems crash to the blue screen of death (now black screen of death) with the "MEMORY_MANAGEMENT" error. However, blue screens of death do not occur if games do not use outdated drivers that are present on the device. The upgrade block was placed on September 30, 2024, and now, nearly ten months later, Microsoft has lifted it. As of July 24, 2025, affected systems can finally install Windows 11 version 24H2 via Windows Update. Note that Windows Update might still prompt you to update games that use an incompatible Easy Anti-Cheat version. Compatibility issues with Easy Anti-Cheat are only present in Windows 11 version 24H2, so if you are running older Windows 11 versions or Windows 10, there should not be any crashes, even with outdated drivers. Windows 11 version 25H2 is coming in a couple of months, but its predecessor still has several upgrade blocks in place. There are compatibility issues with Intel Smart Sound Technology drivers, hanging apps that use the camera, audio output losses on PCs with Dirac Audio, and sprotect.sys driver issues.
    • XRECODE3 1.169 by Razvan Serea xrecode3 is a converter and audio-grabber which allows you to convert from mp3, mp2, wma, aiff, amr, ogg, flac, ape, cue, ac3, wv, mpc, mid, cue ,tta, tak, wav, wav(rf64), dts, m4a, m4b, mp4, ra, rm, aac, avi, mpg, vob, mkv, mka, flv, swf, mov, ofr, wmv, divx, m4v, spx, 3gp, 3g2, m2v, m4v, ts, m2ts, adts, shn, tak, xm, mod, s3m, it, mtm, umx, mlp to m4a, alac, ape, flac, mp3, mp4 (using NeroAAC), ogg, raw, wav, wav(rf64), wma, WavPack, mpc, mp2, Speex, ofr, ac3, aiff, tak, snd and Shorten formats. Command Line parameters are supported. XRECODE3 features: Works on XP, Vista, Windows 7, Windows 8, 10 32/64 bit versions and under Wine. Parallel conversion by utilizing power of multi-core CPUs. Support of embedded CUE sheets (for FLAC, WavPack, APE and TAK files). Support of mp4, mka chapters (can split mp4, mka by chapters to any supported format). Built-in Metadata editor with Cover Art support. Has support for LossyWav. Supports portable mode. Merge input files to one large audio file and create CUE sheet. Converting to many formats at once using "Multiple" output mode. Grabbing of multi-channel Audio CDs to the desired format at once. Informative and resizable UI suited even for netbooks. Extracting audio from flv, avi, mov etc. video files (multiple audio streams are supported). Can export/import Metadata to/from external file. Support for 24/32bit audio files. Multilanguage support. Currently program is available in Dutch, English, French, Japanese, Korean, Polish, Russian, Hungarian, Italian, Spanish, Spanish Traditional, Swedish, Brazilian Portuguese, German, Finnish, Bulgarian, Czech, Danish and Chinese (simplified) languages. What's new in XRECODE3: Native 64bit support. Added support for DSD/DST and DFF formats (including handling of SACD ISOs). Added option to extract audio without transcoding. Added option to encode several files to one multi-channel file. Added option to split file into individual track-per-channel for all available output formats. Added option to merge files per folder. Output and Metadata settings are now output format specific. Enhanced Metadata settings. Added support for multiple Cover pictures in Metadata editor. Added 32bit int/float output for formats which support them (e.g. WAV). Added dithering option in Output Settings. Added option to use EBUR128 in Normalize. Added option to Album Mode Normalize. Added option to configure Matrices under Output Settings. Added more output file pattern elements. Tabbed UI. CUE files are now displayed more nicely. Enhanced Shell Extension. XRECODE3 1.169 changelog: FIX: resolved an issue where playlist file names was created with 2 dots before the file extension. FIX: fixed issue with encoding some files to ac3 format. Download: XRECODE3 v1.169 (64-bit) | Portable | ~30.0 MB (Shareware) Download: XRECODE3 v1.169 (32-bit) | Portable Link: XRECODE3 Homepage | XRECODE3 Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
      Itbob513626 earned a badge
      EdwardFranciscoVilla went up a rank
      MoJo624 earned a badge
    • Collaborator
      aeganwn earned a badge
      Collaborator
      160
      123
