Exploding Water
Found this.
http://www.snopes.com/science/microwav.htm
Claim: Consumers need to be cautious that water boiled in a microwave oven can suddenly "explode."
Status: True.
Example: [Collected on the Internet, 1999]
Microwaving Water to Heat it Up
I feel that the following is information that any one who uses a microwave oven to heat water should be made aware of. About five days ago my 26-year old son decided to have a cup of instant coffee. He took a cup of water and put it in the microwave to heat it up (something that he had done numerous times before). I am not sure how long he set the timer for but he told me he wanted to bring the water to a boil. When the timer shut the oven off, he removed the cup from the oven. As he looked into the cup he noted that the water was not boiling but instantly the water in the cup "blew up" into his face. The cup remained intact until he threw it out of his hand but all the water had flew out into his face due to the buildup of energy. His whole face is blistered and he has 1st and 2nd degree burns to his face which may leave scarring. He also may have lost partial sight in his left eye.
While at the hospital, the doctor who was attending to him stated that this a fairly common occurrence and water (alone) should never be heated in a microwave oven. If water is heated in this manner, something should be placed in the cup to diffuse the energy such as a wooden stir stick, tea bag, etc. It is however a much safer choice to boil the water in a tea kettle. Please pass this information on to friends and family.
Origins: Huh?
Exploding water? True? Not true? What?
In a nutshell, yes, water can "explode" in this fashion. However, it takes near perfect conditions to bring this about, thus "exploding water" is not something the average hot beverage drinker who would otherwise now be eyeing his microwave with trepidation need fear. Odds are, you'll go through life without ever viewing this phenomenon first-hand, and if you're one of the rare few who does get to see it, you will likely not be harmed by the experience (that would take you standing right over the cup at the instant it happens and the liquid bolting up and hitting your skin).
The e-mailed warning is a model of non-specificity (no names, date, or locale; only the detail that the "victim" was 26 years old, presumably to enforce the idea that this accident could not be blamed on a child's typical lack of caution), leaving us able to address only its theoretical aspects. Unfortunately, our eyes glaze over whenever we have to write about science topics, so we'll just note that a bunch of other science-type people think it's plausible, although the phenomenon isn't nearly as common as the message cited above might make it sound:
In an article in New Scientist, Richard Barton wrote:
A portion of the water in the cup is becoming superheated ? the liquid temperature is actually slightly above the boiling point, where it would normally form a gas. In this case, the boiling is hindered by a lack of nucleation sites needed to form the bubbles . . . I imagine that by keeping the cup still and microwaving for a long time, one could blow the entire contents of the cup into the interior of the microwave as soon as you introduced any nucleation sites. It is this sometimes explosive rate of steam production that means you should take great care when using a microwave oven.
From the How Things Work web site:
In general, leaving a spoon in a cup of coffee or bowl of oatmeal isn't going to cause any trouble at all. I do it all the time. In fact, having a metal spoon in the liquid may reduce the likelihood of superheating the liquid, a dangerous phenomenon that occurs frequently in microwave cooking. Superheated liquids boil violently when you disturb them and can cause serious injuries as a result.
From the Unwise Microwave Oven Experiments web site:
Things are different in a microwave oven. The water gets hot but the container usually does not. There are no "boiling-bubbles" triggered by a hot metal pot. Without those bubbles to cool it, the temperature of the water rises far higher than 100C. We call this "superheated water." Superheated water is just waiting for some sort of trigger which will let bubbles form and allow boiling to commence. If the water becomes hot enough, a few bubbles will appear, but these quickly rise and burst, and the water isn't cooled much at all. In the microwave oven, even if your mug of water is bubbling slightly, don't trust it, since it's temperature has risen so high above 100C that bubbles are appearing spontaneously. If some unwitting victim should pour a soluble powder into the superheated water, this will carry thousands of tiny air bubbles into the water. Each of these micro bubbles expands into a 1cm steam bubble, and the result is a huge "explosion" of hot froth. It's just like dumping ice cream into root beer, but the froth can be so violent that the hot water sprays into the air.
If you're really worried about this happening to you, follow the advice and leave some non-metallic object (such as a wooden spoon or stir stick) in the cup when you boil water in the microwave. It may not be necessary, but it won't hurt anything either. Peace of mind rarely comes so cheaply.
https://www.neowin.net/forum/topic/97856-exploding-water/
i have also noticed this once heating my water in the microwave (i normally set it on high for 3 minutes). sometimes when i get really bored i dump a teaspoon of sugar into the water (while it is in the microwave of course), and i like watching it fizz up :huh:
one thing which i do to fix this problem is to "diffuse" all the energy in the water by putting a spoon in the cup and mixing the water around. regardless, i find using the kettle is much more efficient, despite the fact it takes 4 minutes to boil, and uses electricity much less efficiently. i find microwaved water "foamy" and leaves a weird layer on top (bubbles).
https://www.neowin.net/forum/topic/97856-exploding-water/#findComment-1123233
  lucasvanos said:
Ok, my grandma boils water in the microwave for about 5 years now but I guess she is just lucky. :whistle:
btw. They can show you anything on tv.
well if u read the article it says it doesnt happen 100%, need near perfect conditions so thereforce u can assume it was bad luck it happened to that guy. jsut because your grandmother doesnt experience it for 5 years doesnt mean it couldn't happen genious.
https://www.neowin.net/forum/topic/97856-exploding-water/#findComment-1123462
i like how you misspelled genius
https://www.neowin.net/forum/topic/97856-exploding-water/#findComment-1123475
  iMike said:
  linsook said:
  lucasvanos said:
Ok, my grandma boils water in the microwave for about 5 years now but I guess she is just lucky.?:whistle::
lmfao oh the irony
https://www.neowin.net/forum/topic/97856-exploding-water/#findComment-1123499
    • let's be honest here, it was in the line of secret doxing app
    • Dating safety app Tea spills private chats in new leak by Usama Jawad Tea is (was?) an extremely popular "dating safety" app designed for women who typically uploaded pictures of men they have dated, recounting their experience, and highlighting red flags. The app maintains exclusivity to women by requiring all its users to submit a selfie and government identification during the sign-up process. It was the target of a major breach a couple of days ago due to a Firebase bucket being left publicly exposed, leaking the identification data and other sensitive information for thousands of users. Now, the app has been struck with a second cybersecurity incident and it is arguably bigger than the first. 404 Media reports that a second database has leaked and it contains about 1.1 million chat messages discussing some sensitive topics that people likely wouldn't want to make public. These include topics like cheating partners, abortions, and unfaithful boyfriends. The messages span from 2023 to last week, but the impact and scope of the leak is unclear. The person who did discover the database noted that practically any user could access the repository using their own API key. In a statement to Bleeping Computer, Tea has confirmed the second breach too, noting that "some" direct messages (DMs) have been exposed. The company has decommissioned the affected system for now, but claims that other infrastructure remains unaffected. It has emphasized that it will invest efforts in the coming days to improve its cybersecurity posture, but did not share any further details at this time. The service will also be reaching out to its affected customers and offer them free identity protection services as a sort of an apology. These cybersecurity incidents further highlight the need to be vigilant when sharing identifiable information online, especially with apps which are very new to the market and have not yet matured. Security researchers and analysts have cautioned the public that it is very possible to locate social media profiles of Tea users due to all the data that has been leaked.
    • 26200.5722 is the first available 25H2 build from the ge_release_svc_betaflt branch (25H2's previous branch was the "ge_prerelease_im" branch). The 26200.5722 release also removes the "Insider Preview" references in the system area. These significant changes usually indicates that the public release of 25H2 will be ready within 6 weeks to 2 months.
    • Microsoft: Windows Autopatch is the safest way to upgrade enterprise PCs to Windows 11 by Usama Jawad A few hours ago, Microsoft published a guide for IT admins explaining how they can use Intune to upgrade Windows 10 devices to Windows 11, while also migrating from Active Directory (AD) to a cloud-native system like Entra ID. The company has also published a similar guide, but switched the tool to Windows Autopatch, claiming that it is the fastest and safest way for enterprise PCs to update to Windows 11. For those unaware, Windows Autopatch is a way to automate updates while empowering IT admins to ensure that endpoints are healthy and compliant through ring-based, staggered deployments. IT admins also have the ability to reverse updates easily if something does go wrong. In the current scenario of upgrading enterprise PCs to Windows 11 using Autopatch, Microsoft has outlined a four-step process. The first involves assessing Windows 11-readiness across your organization, assigning Entra ID groups to devices, and then mapping these groups to rollout rings in Autopatch. Next, IT admins should segment devices into Windows Autopatch groups, while also defining staggered rollout policies controlled through rollout rings. At a base level, there should be two groups: devices that meet the criteria of Windows 11 and should upgrade to it, and Windows 10 hardware that doesn't meet the criteria and should receive Extended Security Updates (ESUs). Devices should be spread in a logical manner across various rings, with each group having a dedicated update policy. The third step involves defining the speed of staggered update rollouts. This can be managed through the Intune admin center, which gives you control over sequencing, pace, and deferrals. Finally, IT admins should monitor the rollout of the Windows 11 update through the Windows Autopatch feature update reporting module. It contains the update status across devices, trendlines within historical views, and remediation guidance for errors. Microsoft believes that this combination of Windows Autopatch groups and Intune is the best way to upgrade to Windows 11, so IT admins should get started right away as support for Windows 10 is ending on October 14, 2025.
    • TDP of this CPU is 60 watts higher than Ryzen 7600. At s usage rate of four hours per day, at a cost of twelve cents per KWh, the Intel cost $10.51 more per year to use. I don't see a real advantage to Intel here.
      ataho31016 earned a badge
      Gladiattore earned a badge
      NeoWeen earned a badge
      165
      107
