- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
eliokh
Hello all,
Im a newbie to C and I am not figuring out how to make a function that will generate a double between 0 and 1...
I KNOW NOTHING ABOUT C but managed to get a hello world work...
I tries this function but i think it's not working properly:
as when i try to display the num with this forloop it's getting me huge negative or positive numbers
another thing, what should i add to the code so i dont allow the program to exit directly after execution and so the command prompt stays opened so i can see the results?
Thanks in advance.
Elio
https://www.neowin.net/forum/topic/980266-c-random-double-between-0-and-1/Share on other sites
21 answers to this question
