- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
classicdisastr
Hello! I'm working on a project that has a little planner feature in it. I'm using jQuery UI with draggable and droppable to move the events from a list of choices to a table with lists in the cells. So far that part is working. What I also need is a way for the events to be removed, so I created a trash div and right now they can be dragged to the trash and they will be hidden from the list. The only problem is that when the events are added initially they remove the placeholder list item so without that other events cannot be added because the unordered list is pretty much non existent to be able to drag to after they have been deleted.
What I'd like to know is how to re add the .placeholder list item when an item from the list is removed.
Here is the test site to look at: http://caseymilstead.com/neowin.html
Thanks!
https://www.neowin.net/forum/topic/984766-jquery-ui-droppable-help/Share on other sites
3 answers to this question
